Fast Intentions TT Kit - Press Release! SOON TO BE AVAILABLE TO THE G!!!
Old 10-23-2015, 11:57 PM
  #256
TelephasicG
TelephasicG's Avatar
Originally Posted by FastIntentions
I will take videos and post a full write up in the days following the dyno.Thanks.
-Tony
Any chance of seeing a dyno sheet and perhaps a video? I also checked your website, no mention of the kit there. Is it for sale?
Old 10-26-2015, 12:04 PM
  #257
Waste86
Waste86's Avatar
May not be the person you are looking for to answer this, but they are selling the kit. I ordered mine at the beginning of July.
1cleanG (10-27-2015)
Old 10-26-2015, 08:55 PM
  #258
Upscale Speed
Upscale Speed's Avatar
How much boost could I run, reliably, on this kit with stock internals and stock 7AT? With exhaust, oil and tranny cooler and Ecutek tuned for supporting mods to start would be my goal.
Old 10-27-2015, 03:33 PM
  #259
1cleanG
NextLevel Performance
1cleanG's Avatar
Any and all Automatics we would HIGHLY recommend an upgraded built transmission with upgraded clutch plates. Personally I have seen forced induction builds on the VQ stock transmission hold around 4-430whp without issues short term(with the transmission cooler), but most of those setups typically lack a desirable torque curve.
Without a boost controller and open waste gate (around 6psi), this kit will already produce that power range with considerably higher torque.
ANMVQ (10-27-2015)
Old 10-27-2015, 04:22 PM
  #260
ANMVQ
ANMVQ's Avatar
7-8 PSI, You want to be around 400-430 WHP but the WTRQ you'd want to keep in the low mid 330's.
Old 10-28-2015, 04:39 PM
  #261
Upscale Speed
So if I went with a build tranny from say Level 10 how much boost would I be able to run on stock internals safely?
Old 10-29-2015, 08:04 AM
  #262
ANMVQ
ANMVQ's Avatar
There's not real answer to that :/ depends on the tune! but I still wouldn't go anymore than 9 maybe 10 PSI, My motor popped on a SC but I was running 12 PSI, Turbos are always hit harder because of the HUGH trq they make.
We also have to worry about the Tcase not sure what the limits are.
Old 10-29-2015, 03:17 PM
  #263
1cleanG
1cleanG's Avatar
We have customers running 10-12psi daily running E85 with zero issues, not even a hiccup.
There are many factors to take into consideration, the two most important would be your fuel system and tune. Your tune & boost controller will control your TQ curves as to when it really comes on hard. A proper fuel setup(upgraded injectors, pump & fuel return system) will prevent the car from leaning out.
ANMVQ (10-29-2015)
Old 10-29-2015, 03:33 PM
  #264
Upscale Speed
Thank you.
Old 11-03-2015, 12:02 PM
  #265
1cleanG
1cleanG's Avatar
Thank you.
You bet. I want to point out this thread on the370 page as well which is very helpful, and shows current AT forced induction builds.
Forced Induction & 7AT 370z Info - Nissan 370Z Forum
Please let me know if you have any other questions or if you'd like to start putting a build invoice together~ Happy to help you get setup!
ANMVQ (11-03-2015)
Old 12-14-2015, 11:29 AM
  #266
1cleanG
1cleanG's Avatar
An awesome side by side compilation of OEM 2015 Nismo acceleration vs post install of the Fast Intentions Twin Turbo Stage 2.
The following 3 users liked this post by 1cleanG:
blnewt (12-14-2015), claudiohv (12-14-2015), Presto (12-14-2015)
Old 12-14-2015, 11:36 PM
  #267
claudiohv
claudiohv's Avatar
Dude amazing shifting skills, I can totally shift like that at 2ooo rpms though.
Cheers for TT Fi kit! No wonder why boost is addicting, may the forced induction be with us all.
Edit: my clutch smells if I shift like that, should I worry? Lmao... No like should I actually worry?
Old 01-29-2016, 08:13 PM
  #268
Byrdman
Don’t Buy From GTM/Gamma
Byrdman's Avatar
Tony has Top Speed Motorsports contacted you at all about my build? I find it silly that my car is just sitting at their shop and you guys are pumping out kits left and right and TSM doesnt have it yet. So much for being the 1st G after George's build
Old 01-29-2016, 08:52 PM
  #269
1cleanG
1cleanG's Avatar
You've got a PM
Old 01-29-2016, 09:00 PM
  #270
FastIntentions
MYG37.COM Sponsor
FastIntentions's Avatar
Hey man,hope all is well on your end. Hopefully back from deployment. I have not been contacted by anyone from Top Speed regarding your car since thelast time you and I spoke.
I'm going to send you a PM with my personal cell number.
Thanks.
-Tony
1cleanG (01-30-2016)
Quick Reply: Fast Intentions TT Kit - Press Release! SOON TO BE AVAILABLE TO THE G!!!
