Differential Swap
Differential Swap
Hi,
I'm new to the Infiniti family, but not so much to performance cars. I just picked up an 08 G37 coupe and have been very pleased with it with the exception of the differential.
I haven't found too much discussion after hours with the search function, but if what I've found is correct then the non s model doesn't have posi and the s model does. I didn't even consider that to be a possibility in a rear wheel drive performance car these days so I didn't ask before I bought it.
Am I understanding this correctly, and if I am is it a clean swap if I pick up a rear diff from an s model?
Thanks in advance.
Thanks in advance.
Thanks for the quick help. I've seen a couple used LSDs on ebay for $300-400. The aftermarket ones I've seen are well over 1k.
As long as its another differential from a 5speed automatic I should be good right? Will any others be a direct fit? Any other compatibility issues?
ck1109
10-15-2015 11:06 PM
delfinparis
10-08-2015 06:06 PM
