Sprint Booster
Old 11-01-2012, 11:19 PM
Mr. Nibiru
Mr. Nibiru's Avatar
Sprint Booster
So I have been debating on getting this since I saw it win a few awards at SEMA. So I broke down and got it and I will post the reviews of it after I install it. If anyone has any experience with this let me know.
Old 11-01-2012, 11:27 PM
nukee26
nukee26's Avatar
So if I'm understanding correctly, this thing just boosts the signal so that the throttle goes more open for a given accelerator position?
Old 11-02-2012, 03:29 AM
NeverBoneStock
NeverBoneStock's Avatar
It works and does the job .. It gets rid of the lag ..
Old 11-02-2012, 03:41 AM
TakmaN
TakmaN's Avatar
Yup it just changes the throttle sensitivity of the gas pedal (kind of like turning on the sport button on the E46 M3). I had it on my E60 545i 6MT and it made driving it beyond awful. I took it off and never looked back. I've heard better reviews of it on automatic cars though.
I forget what it is called, but there's a similar product which allows you adjust the sensitivity via a remote/adapter.
Old 11-02-2012, 04:27 AM
hechen507
hechen507's Avatar
IMHO its not worth getting since it render a certain amount (depend on the gain of the device) of the pedal travel useless. For example if the device has a gain of 2 at 10% pedal travel your car would think you did 20% and at 50% you car would think you are at 100% and anything above 50% your car would still think its at 100% travel. To me it would be much easier to adjust your driving style rather than throwing away your pedal travel. It will be X (gain) amount harder to control your throttle.
Old 11-02-2012, 04:46 AM
j23a45m
j23a45m's Avatar
this product has nothing to do with pedal travel. what it does is get rid of the lag in the drive by wire system!
Old 11-02-2012, 05:34 AM
hechen507
hechen507's Avatar
From my understanding of sprint boosters (like this one https://www.sprintboostersales.com/installation.cfm) all it does is amplifies the signal voltage from the throttle pedal. Your pedal does not have any "lag". At 0% travel it will outputs instantly ~0V and at 50% ~2.5V and 100% pedal travel it will instantly output 5V this is due to its electrical properties, most likely a resistor and a potentiometer is parallel at its simplest.
The only reduce lag I see is the throttle travel.
For example if it takes you 50ms to depress the throttle from 0% to 100% travel with a sprint booster with a gain of two it will only take you ~25ms since you will only need to go half way to achieve the same output. But again this is not without its draw backs anything over 50% throttle travel is still register as 100% throttle thus half of your throttle travel is useless.
Old 11-02-2012, 06:42 AM
NeverBoneStock
Here goes the good ol pedal travel debate . Next people are going to start chiming on and saying all u have to do is smash the pedal everywhere u go . It gets rid of the lag .. It does the job
Old 11-02-2012, 12:23 PM
Mr. Nibiru
Mr. Nibiru's Avatar
I am thinking it is like Takman explained. It has 3 settings so if you don't like it you can turn it off. I just like the thought of adjusting the "performance" of the car. I will definitely be unbiased on the review. I don't expect extra power, just better response from the acceleration.
Old 11-02-2012, 12:36 PM
Nothin2Somethin
Nothin2Somethin's Avatar
Definitely post your opinion. I too have been looking into purchasing this.
Old 11-02-2012, 01:24 PM
Tazicon
Tazicon's Avatar
It wil be nice to hear an honest assessment. I look forward to seeing what you find.
Old 11-02-2012, 01:30 PM
Robert Green
Robert Green's Avatar
Should just get the Uprev tune. 20hp and reduced lag.
Old 11-02-2012, 05:12 PM
j23a45m
j23a45m's Avatar
yes im with you man.
I had this on my 2002 maxima, so i know first hand on how and what it did in the car. I guess i give up on saying what it does from first hand use
Old 11-02-2012, 05:46 PM
daren_ipl
daren_ipl's Avatar
I don't know about the sprint booster but I know first hand experience to reduce the lag in 7AT cars I used a grounding kit while in ds mode I can guarantee you'll see a difference. I also curious to see the outcome of the sprint booster
Old 11-02-2012, 07:24 PM
Polar_g37s
Polar_g37s's Avatar
Spring booster is for cheapos and a reflash is for men. Reflash will gain you hp and you can mess with the throttle positions..
Quick Reply: Sprint Booster
