Software CONSULT tool - anyone used this?
There are 2 that are PC based there is consult III. And consult III plus(pretty much dubbed c4) .....for everything i believe its around 12-13k
I use a bluetooth OBDII adapter along with the Torque app on my phone. It will give you real time data on the engine. I'm not 100% sure if it monitors the transmission, but it probably does. If you have an android phone, it's about $20 for the adapter and $5 for the app.
Adapter I purchased:
App:
https://play.google.com/store/apps/d...l.torque&hl=en
-Brian
BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive
App:
-Brian
App:
-Brian
App:
-Brian
Outside of the obvious price differential, how does that compare to the Kiwi?
While the Kiwi is most definitely a better product, I haven't had one bit of trouble with my adapter. I've only had it for a month, but it syncs perfectly.
As for the iPhone, its bluetooth radio is proprietary. Apple will not allow app designers to interface with it in their apps. Therefore, these cheap bluetooth OBDII adapters can't communicate with the iPhone. There are other solutions (wifi), but they start at about $150.
-Brian
-Brian
I just went out to my car to try getting transmission temp readings and it looks like the G37 doesn't pass that information over OBDII. There was an option to create a gauge, but the gauge just read 0 degrees.
-Brian
-Brian
Do we even have a temperature sensor for trans fluid?
As far as OBDII readers go, I think Uprev's cipher is best. $200 gets you good accurate readings on your laptop. No connection issues or any of that.
37
10-17-2020 11:12 AM
delfinparis
11-16-2015 02:26 PM
gdaelemans
09-15-2015 12:20 PM
