slave cylinder
slave cylinder
Hello everyone. I dont know if i spelled that right. Anyhow i just got through a debacle with tustin infiniti regarding my slave cylinder in my 2009 g coupe. I hear its a common problem among g/z cars. They recommended i replace both the slave and the master. I had them just do the slave and the car drives like it just came out of the factory. I did this because i talked to multiple sources who told me the dealership was trying to rig more money out of me. It started when my clutch pedal was sticking to the floor. Everything else was fine. The dealer tried to convince me to replace both the slave and the master. Were they trying to get more money out of me? Please give some enlightenment to me.
Cheers.
Cheers.
Just say no!!!!!
Do a search on here. There's several lengthy threads on the topic. In general, it is recommended to do both. Especially on a car with significant miles. On the other hand, the master is a whole lot easier and cheaper to replace than the slave. To increase the life of either/both, flush your clutch fluid at least once every 2 years or sooner.
This is funny (not really) because I just went through the exact same thing in my 08 coupe. I have another thread on here as well. The dealership ultimately replaced the Master cylinder. Like JSolo said...its cheaper for them. I would've preferred to have both done but...eh.
Not absolutely necessary to replace both but it's best to do it if you can. If you replace clutch or flywheel it's crazy not to at least replace slave while the transmission is dropped. Because I can tell you that if you don't you'll be paying 5+ hours of labor to drop it again when the slave dies. Master is cheaper and takes less labor to replace. Don't be cheap. If one is dying, replace both. How are you going to be 100% certain which one is causing the problem?
Guys i think my slave or master might be starting to cause me problems. I cant shift quickly from first to second or sometimes even third anymore. It feels like even with the clutch pressed all the way to the floor it grinds just moving the shifter. Then when i shift to third quickly sometimes the clutch will slip for about 1/4-1/2 a second before the rpms drop a bit and it fully engages. Are these early warning signs? I only have like 9000 miles so I highly doubt the clutch is worn out.
Just say no!!!!!
I think an obvious sign would be the pressure needed to depress the pedal changing. That is, pedal stays soft longer before building up pressure - engagement point changing too. The latter is harder to quantify unless the change is substantial and overnight. Otherwise you get used to it and difficult to notice.
Once the CSC starts leaking, it's just a matter of pedal strokes until the reservoir is run dry. So if you notice it happening, try using the clutch less and/or move to a safe area for tow. The reservoir is relatively small, holding several ounces at most (probably 2-3 shot glasses).
