Stillen SC Build = 500 WHP?
Old 10-10-2012 | 12:12 PM
  #46
ANMVQ's Avatar
ANMVQ
Dayyyum! Your motor must be detonating pretty crazy! Have they checked the:
Fuel pump
Fuel injector
Fuel pressure
Doing all the above today, The injectors should be good since there fricken brand new, but my guess would be the pump is shot, we'll see what they say.
Old 10-10-2012 | 01:52 PM
  #47
Weiboy718's Avatar
Weiboy718
Regardless I would still double check the injectors to make sure they're installed correctly. You never know what the techs at the dealership does. All it takes is the rubber gasket not seated properly on the injectors and causes you problems.
Old 10-10-2012 | 04:58 PM
  #48
ANMVQ's Avatar
ANMVQ
Agreed 100%, I'm sure they are looking at the whole fuel system.
Old 10-11-2012 | 10:49 AM
  #49
ANMVQ's Avatar
ANMVQ
So only update today is NO update till the end of the month, Was told this morning ,The most likey will not have to look at the car till the week of 24th? This week slammed, and they are preping for a open house this weekend, Next week slammed, and have a track day on Tuesday, So really nothing till the week after.
Old 10-11-2012 | 11:12 AM
  #50
Weiboy718's Avatar
Weiboy718
You need this!
GOOD LUCK!!!!!!
Old 10-11-2012 | 01:55 PM
  #51
Elperuano's Avatar
Elperuano
You need this!
GOOD LUCK!!!!!!
Couldn't agree with this more(where's the like button!), good luck getting it sorted out. I'm sure it'll be an absolute blast to drive it again. Hopefully in time for Christmas!
Old 10-11-2012 | 04:09 PM
  #52
ANMVQ's Avatar
ANMVQ
Would be a nice Xmas gift, LOL Get to drive the car again, ,,
Old 10-22-2012 | 05:05 PM
  #53
ANMVQ's Avatar
ANMVQ
So a quick run down off what we did today, We found that the feed line was installed wrong or was the wrong type of hose all together, and swapped the fuel pump out with a DW300, along with of course replacing the feed line, We also found that this fixed the leaning issue, But of course now the car will only make 3PSI, was told the cogs are wrong and should be removed because they are putting to much load on the supercharger and cocking it to the side, bending the bracket or bending the SC shaft so it will not spin. So basically I am so done with this car and these issues I told them to feel free on putting the Stillen pulleys back on and retuning it, I realu just do not acre at this point , So feed up with towing it here and there..
Old 10-22-2012 | 11:38 PM
  #54
Weiboy718's Avatar
Weiboy718
Something I don't quite understand here, so how were you able to run for a few months without issues if your fuel pump feed lines were indeed installed incorrectly?
Installing the stock pulley might be a great idea since nobody seems to know what they're doing over there.
Guess your 500 WHP is wish ends here!
Good luck again!
Old 10-23-2012 | 11:33 AM
  #55
ANMVQ's Avatar
ANMVQ
exactly, they where able to run the car for 10 mins and no issues, The lean issue came right back, I'm with you something doesnt add up, Did not even swap the pulleys.
The feed line was cracked, Dont know when that happened but I had been driving the car and very hard at times, One more try before I strip this thing to stock and sell it,,
Going to The Shop CT, I really hope Jimmy can figure this out, He did wonders with Coops car, Just hope he can get mine to run,
Old 10-26-2012 | 08:14 PM
  #56
ANMVQ's Avatar
ANMVQ
Ok.so just got off the phone with Jon @ Kaizen........... Car made 454WHP..@ 10 PSI. No cogs stock Stillen 8psi grey pulleys and the turbobsmart BPV.
Old 10-26-2012 | 08:28 PM
  #57
G37Stampa's Avatar
G37Stampa
great numbers,congrats!
Old 10-27-2012 | 05:05 AM
  #58
G37Sam's Avatar
G37Sam
Oh wow!! Glad to hear she's in good hands man!
Old 10-30-2012 | 05:24 PM
  #59
ANMVQ's Avatar
ANMVQ
Yea was super happy to get it back. just had the P006A code turned off this morning also. Car is super responsive .
Old 10-30-2012 | 06:15 PM
  #60
Kidcane's Avatar
Kidcane
Florida G Club
Wow, this is just now getting resolved?!! I have not been on here for months. Props to you for being the most patient person EVER!!
