newbie asking about fuel type
Old 06-30-2012, 07:22 PM
Wyldfyer
Wyldfyer's Avatar
Put super in your car. But if you have to put 89 grade in there, absolutely nothing will happen.
Old 06-30-2012, 07:47 PM
Audi_2_G37x
Audi_2_G37x's Avatar
Originally Posted by KAHBOOM
Yeah even if to fill up from completely empty, you are not saving a significant amount of money. The difference might be 10 cents per gallon from mid to premium. That would be $2.00 a fill up. If that's going to break you, then in my opinion you are in too much of a financial crisis to be driving a $40k vehicle.
Couldn't have said it better. People always complain about premium being "so much more expensive." If you cannot afford a few bucks extra to put the correct gasoline in your car then you should not be driving that car.
Old 06-30-2012, 08:43 PM
TwoThree
TwoThree's Avatar
Amen.
Old 07-01-2012, 04:11 AM
xxg00w0
xxg00w0's Avatar
are you sure that's a 12?? it looks like 08-10 to me....
Old 07-01-2012, 09:00 AM
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
If you zoom in closely you can see the sensors on the bumper. Those weren't on the 08-10
Old 07-01-2012, 10:19 AM
jmueller
jmueller's Avatar
Noticeable improvement in fuel economy using 91 or 93 compared with 87. It easily pays for the 2 or 3 dollar increase using the premium fuel. Don't cheap on gas. It's not worth it!
Old 07-01-2012, 09:27 PM
mikeeeeey
mikeeeeey's Avatar
Thank you all, you've been a great deal of help. Premium it is!
Old 07-01-2012, 10:02 PM
VRG37S
VRG37S's Avatar
Since were on this topic, I have a fuel question for you guys myself. I always run 91 in my G since its all you can get at the pumps in socal. Are there any benefits to running some Octane booster in the car to try and make the 91 like 93 or a littler higher octane? I figured since its summer here in socal the G might like a little higher octane fuel to run better. Thanks for your help?
Old 07-01-2012, 10:05 PM
Str8shooter
Str8shooter's Avatar
First of all, congrats Mikeeeeey!! All I use is Premium 93 at the pump. I am very particular on which brand or company as well. I stick to Shell or BP. I wouldn't take a chance with cheaper or a lower grade gas. As some of the other members have already mentioned, it's definitely better for engine performance and efficiency, if you stick with Premium 93.
Old 07-01-2012, 10:47 PM
g37guy01
g37guy01's Avatar
I use top tier gas when I can, around here we can get 93 octane. I would also follow the break-in period specified by the owners manual.
While there are a lot of differing opinions on how to break in a car on the internet, I don't think Infiniti wanted to waste ink by declaring on page 5-43
During the first 1,200 miles (2,000 km), follow
these recommendations to obtain maximum
engine performance and ensure the future reliability
and economy of your new vehicle.
Failure to follow these recommendations may
result in shortened engine life and reduced engine
performance.
● Avoid driving for long periods at constant
speed, either fast or slow. Do not run the
engine over 4,000 rpm.
● Do not accelerate at full throttle in any gear.
● Avoid quick starts.
● Avoid hard braking as much as possible.
Instead of: "Drive it like you stole it"
Old 07-02-2012, 07:35 AM
Coprolite
Coprolite's Avatar
Originally Posted by chuckie311
break it period is drive it like you would any other day!! these engines are built no need to baby it
What do you mean by built? Hand built like a GTR engine or built like all other Nissan engines? If you meant the latter, you would be correct.
I don't think that there are any benefits that you would notice. If it got better gas mileage, it would probably be offset by the cost of the additive. If you try it out, let us know how it works.
Old 07-02-2012, 09:18 AM
csnpsu
csnpsu's Avatar
Originally Posted by nukee26
There's a reason the owners manual specifically calls out 91 octane or higher. I'll listen to the engineers that created this car before I listen to anybody from a dealership.
Wow, you believe everything you read? They are all in on it with the gas companies. Just like some cars have mobile 1 on the oil cap when any synthetic will do.
Anyway this is the age old debate that will rage on, put whatever you feel is right but I have been on regular for 3 years and my car runs great. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 07-02-2012, 10:01 AM
criledo
criledo's Avatar
I've read that Citgo has crappy gas :/[/quote]
Besides the fact that if buying from them it is support for a communist tyrant, Chavez......
Old 07-02-2012, 10:11 AM
  #29
criledo
criledo's Avatar
mikeeeeey:
1. Lower octane fuel will cause the engine to run a lot hotter. These high performance engines need high octane fuel, period. For a while I used regular on an A6, I burned 2 coil packs that are bolted to the block (they were burned by high temperature) and the spark plugs were completely red when they were pulled. The mechanic's one and only comment was that this car was seeing regular fuel instead of the required higher octane one.
2. The difference in price from regular to super is probably about 20 cents. That in 14 gallons is $2.80. It's not really worth it, is it........
Old 07-02-2012, 11:33 AM
  #30
2008G-Man
2008G-Man's Avatar
Besides the fact that if buying from them it is support for a communist tyrant, Chavez......[/quote]
Would NEVER buy from Citco!
Quick Reply: newbie asking about fuel type
