Oil cooler for daily driver?
How many of you are running an external oil cooler on your G37s? I live in Texas where it is usually in the low 100s all summer long, and our summers are very long. I just bought an 08' G37s coupe, and am wondering if I should do this mod or just leave it alone. Thanks for the input...
Randy
Randy
Wouldn't hurt but prolly wouldn't help a whole lot.
i just bought one from z1motorsports...it's on sale and is the cheapest i found online for a complete kit....
It comes with a thermostat oil sandwich plate so it allows the oil to warm up properly and keeps it at a constant temperature....
i've had it on my car for about a week now, so far so good, no problems...only thing is i hear a whining sound now from the sandwich plate....and the pitch goes up and down depending on the rpm's (makes sense, since the oil pump is motor driven).....
and i installed it myself, on a scale of 1 to 10, i would say maybe a 7....u'll definitely wish you had a hoist to install it if you don't have access to one...hardest part was running the thick oil lines
The thermostat is there so you don't run cold oil. Oil needs to be at a certain temperature to flow properly. The thermostat will bypass the oil cooler until it reaches that temperature.
As a daily driver, most likely the oil cooler will be in bypass mode almost always.
[QUOTE=gtracing;3475497only thing is i hear a whining sound now from the sandwich plate....and the pitch goes up and down depending on the rpm's (makes sense, since the oil pump is motor driven).....
and i installed it myself, [/QUOTE]
Sounds like a restriction of some sort.
I'm seriously considering adding one as well here in TX. Is it absolutely necessary? Probably not under 95% of circumstances. Am I going to go ahead and spend $300 to build a DIY one for the 5% probability of "just in case"? Yes.
If you are reasonably technically adept at working on your car you can build your own form individual components as good or better than the kits from Stillen, Z1 Performance, etc. There's nothing wrong with the ones they sell, in fact they are excellent. But DIY gives you a choice in components and doesn't make you buy Setrab cooler which are great but on the expensive side.
I heard of a few people using old motorcycle radiators and old sidemount intercolors from Volos and retroing them into oil coolers. Making your own shouldn't be hard, most use and adaptor by on the filter to work.
like most people are saying "do you really need one?" well my answer is also no...i don't NEED an oil cooler, however, it's just a piece of mind for when i do decide to spirit drive it up the mountain or decide one day "yea, i am gonna track it once".....
i also looked at piecing together my own oil cooler. It's easy, however, most of the parts i considered in this oil cooler was identical to the one offered in the z1 kit (Setrab core with mocal thermostat sandwich). It just so happened that the kit was also on sale, and after comparing prices and shipping, etc, it worked out almost the same price! Obviously i chose the kit that came with instructions and all the other misc items, and to top it off, the z1 kit came with mounting brackets for the oil cooler, which isn't supplied if you piece it together on your own.
sorry for the late reply, but yea it does, however after searching on google, i found that a lot of other cars running aftermarket oil coolers also have the same noise. It's just the oil flowing through the lines and through the restrictive fittings, etc that causes the noise. Since it's under pressure, it doesn't really make a difference in terms of flow and performance
Oil cooler noise?
Never heard this before from an oil cooler setup. Does this occur with the Z1 kit, GTM's kit and others as well? I've installed oil coolers on numerous cars in the past and never noticed any noise coming from them due to oil coursing through the lines or the oil cooler itself. What gives?
Al
Update 7/12/12
Just installed GTM's oil cooler kit for my 2012 G37S and have noticed no strange whirring noises and such after the installation. Also switching to full synthetic oil also seems to make the engine run a slight bit smoother. I have anecdotal evidence that the cooler seems to be doing it's job. When I finish using the car and park it in the garage, I always open the hood to allow the engine to cool without cooking everything else in the engine compartment or the hood. Seems to me that the amount of high heat from the engine seems to have diminished. The engine compartment just doesn't seem as "HOT" as it once was. I've also noticed that a battery recharging plug I installed when I first bought the car, no longer feels very hot or soft right after driving the car and when I connect it to the battery charger. Again all these observations are anecdotal since I have no way of checking engine oil temp. right now but I'm a believer in the benefits of the oil cooler in lowering the oil temps.
Al
Update 7/12/12
![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
4DRZ
Engine, Intake and Exhaust
12
05-18-2017 11:25 AM
4DRZ
10-02-2015 09:54 AM
