Engine running rough after filter cleaning
Hey guys I have the Injen CAI and last weekend I took off the air filters and rinsed them with water and let them air dry. The filters are blue and per injens website they are oil free or "dry" filters so I didn't oil them before reinstalling. I drove the car a couple times this week without issue but today after about 1 minute of just getting on the road the engine started to run really rough and felt down on power. I could feel the engine shake through the tranny the CEL came on. I Unplugged the battery to reset the ecu but it continued to misfire. I was close enough that I drove the car gingerly home but on the way it went back to normal. Doesn't sound like its misfiring now. Car has 22k on it. I checked the intakes and everything is plugged in and hooked up tight no obvious leaks. What else could be causing my misfire? I don't think I have enough miles to have issues with spark plugs fuel injectors head gasket etc. Is it most likely something from messing with the filters? I'm debating whether I should call Infiniti roadside right now or wait until Monday and take it in.
Any advice? Thanks in advance.
Jsolo I edited the post and took out my dumb comment. I referenced a distributor cap and spark plug wires.
I didn't touch the MAF sensors only the cone filters.
Update: had the codes read at autozone and it said multiple misfires. Going to just get it checked out by a mechanic.
Multiple misfires can be by caused by hydrolock.
How long did you air-dry the filter before putting it back on?
FWIW, the Amsoil filter that Injen uses are not washable. You're supposed to just vacuum/blow on it -- AMSOIL Ea Synthetic Nanofiber Air Filter (EaA)
It's possible the filter was still fairly damp, or washing it with water may have deteriorated the filter element and eventually got sucked into the engine.
Just guesses here, though. Better get that engine checked before further damage is caused.
KZK
Canada
09-02-2015 05:30 AM
