Z1 Motorsport Driveshaft B4 / After Dyno G35
Old 10-07-2012, 09:13 PM
  #121
Rad_Slinger
Rad_Slinger's Avatar
jeremy, how hard was it to install?
i've heard mixed thoughts on the "ease" of installation.
Old 10-08-2012, 02:38 AM
  #122
It was easier that I thought it would be. The hardest part of installing it was removing most of my MD exhaust (everything except the Y pipe) and reinstalling it. The driveshaft itself was very easy. I do not have access to a lift, I did this with just the rear of the car on jack stands. You must remove 2 aluminum heat shields that have 4 small nuts and and 6 bolts respectively. There are 2 nuts holding the bearing where the 2 parts of the OEM shaft connect and 4 nuts bolts that fasten the rear U joint of the shaft to the flange of the rear differential. None are difficult to access at all.
Scale of difficulty - 4 out of 10. I did it by myself without a helper and didn't need air or power tools.
Old 10-08-2012, 10:54 AM
  #123
qpham45
qpham45's Avatar
Does anyone know is this is available for the sedan?
Old 10-08-2012, 12:07 PM
  #124
Nope. Not that I know of.
Old 10-08-2012, 12:58 PM
  #125
Rad_Slinger
Thanks. Contemplating doing this when I hang my FI exhaust since ima be up there anyway.
Old 10-08-2012, 01:52 PM
  #126
Doing it while installing exhaust is ideal because the exhaust must be partially removed to install the drive shaft anyway.
Old 10-09-2012, 02:55 AM
  #127
WARAT
WARAT's Avatar
That's some good news J. I've hold off into modding for a while but this mod has been on my list since page 1. How's the butt dyno?
Edit. Is this product currently discontinued? I looked at their website and can't seem to find it.
Old 10-09-2012, 12:10 PM
  #128
I don't know if they are still making them anymore, I thought I read a post somewhere on the forum where they were no longer being being made. Don't know if that's permanent or temporary. If you're seriously interested, give them a call.
Butt dyno notices a distinct difference. Unfortunately I live too far out in the sticks and don't have the time to have gotten a before dyno, brought the car home to do the swap, and go all the way back to get an after dyno. I saw all I needed to see on the G35 dyno posted at the beginning of the thread. Revs come faster both up and down. However keep in mind that I also have a lightweight flywheel and so I've shaved about 24 lbs of rotational mass between the engine and rear differential.
Old 10-09-2012, 01:29 PM
  #129
Staples
Staples's Avatar
I've had the driveshaft installed for almost 5 months now. Still loving it and not having a single issue. I know it made power because comparing tunes with others and DynoJet numbers, I'm making similar power with LESS timing. Methanol direct port kit is being installed as we speak. Should make a couple extra ponies reliably.
But yes, I would recommend it for sure!
Old 10-11-2012, 04:40 PM
  #130
WARAT
WARAT's Avatar
Yeah I'll have to give them a call.. Sad if they discontinued it permanently.
Old 10-11-2012, 05:36 PM
  #131
zokissima
zokissima's Avatar
Hey can you post up what you find? I'd be interested in picking one up, if that would be more incentive for them...
Old 10-11-2012, 06:07 PM
  #132
vokhoa408
vokhoa408's Avatar
I'm interested too!
Old 10-11-2012, 07:49 PM
  #133
kaoticdemize
kaoticdemize's Avatar
emailed them, waiting for a response, had this on my 300zx loved it.
Old 10-16-2012, 01:37 AM
  #134
WARAT
WARAT's Avatar
Good news. Its still in production. No set date when they will release it again but I was told "soon".
Old 10-16-2012, 06:48 AM
  #135
Bong1012
Bong1012's Avatar
^^I got the same message from them too.
Quick Reply: Z1 Motorsport Driveshaft B4 / After Dyno G35
