Z1 Motorsport Driveshaft B4 / After Dyno G35
Old 05-14-2012, 08:44 PM
  #46
hustlerj
hustlerj's Avatar
Is the driveshaft for manual only?
Old 05-14-2012, 11:35 PM
  #47
Staples
Staples's Avatar
Originally Posted by Romeo0119
Ok 3 questions? How much is it and when will the auto one be available? Also is it ok to replace this in a stock engine? Somebody needs to post a DIY for this after they get it...
1. $428 plus shipping (Before discount of $25).
2. The drive shaft for the automatic will be available in 3 - 4 weeks.
3. Yes completely safe.
Old 05-15-2012, 02:49 AM
  #48
G37Sam
G37Sam's Avatar
Out of curiousity, what does an OEM drive shaft go for?
Old 05-15-2012, 09:00 AM
  #49
ANMVQ
ANMVQ's Avatar
Cound find a new one on-line from Infiniti, Found one for $428 tho?
Old 05-15-2012, 09:14 AM
  #50
Modme
Modme's Avatar
458.06 from orderinfiniti
Old 05-15-2012, 09:29 AM
  #51
G37Sam
G37Sam's Avatar
So if the price is almost similar to OEM and the AL one is claimed to be stronger yet lighter, why would Nissan engineers ditch that option and go with a heavier, more complex steel drive shaft with an extra u-joint?
Wouldn't the lower rotational mass help them achieve better performance, better mileage and emissions?
Old 05-15-2012, 09:57 AM
  #52
Sam you well know that corporate level decisions are made on how cars are built with performance in mind, but never as a primary concern over profit except on some supercars. Cost and meeting a specific price point force compromise in every single aspect of design and construction of mass produced vehicles.
Why? There could be a number of different reasons. Their cost is probably cheaper for the steel shaft from their material and part suppliers. They aren't particularly concerned by the extra weight and rotational mass vs the cost savings.
The same reason our cars don't come with super lightweight forged wheels. Or carbon fiber body panels. Or dual clutch transmissions. Or...
Old 05-15-2012, 10:41 AM
  #53
TVPostSound
TVPostSound's Avatar
Originally Posted by Staples
The reason our cars can't use a 1 piece is because it's made of steel (for certain safety reasons). .
BS, I disagree. Steel driveshafts have been made much longer in 1 piece for many many years. The only reason Infiniti or anyone else, would make a 2 piece shaft, is to minimize the angle of the u-joint. Halving the deflection of each joint.
By removing one joint, you now increase the angle of the single joint.
Not something I would have, especially if I changed the geometry of the car by lowering it.
Thats the reason another poster has a noise, the u joint is taking too much stress.
Not for me!!!
Old 05-15-2012, 11:32 AM
  #54
G-Rex
G-Rex's Avatar
Not for me!!!
Agree with TVPostSound. Geometry is an important consideration, but an additional concern relates to driveshaft "whip". Essentially, at very high rotational speeds the driveshaft has a tendency to bow outward from centrifugal force. As you can imagine, this would cause severe vibration and has the potential for catastrophic failure.
The longer the driveshaft, the greater the tendency for whip (not sure if this is a linear correlation; may be greater than linear). Thus, two short shafts with a central U-joint may be preferable to a single shaft built strongly enough to withstand the whip.
This is also why the tendency toward carbon fiber driveshafts, which can be engineered for stiffness (to resist whip) along with torsional strength. Bearing all this in mind, I'd have to ask a lot of questions before taking this step.
As a separate issue I'm unclear as to why the apparent bump in horsepower/torque? The result of a reduction in driveline friction losses? If so, why isn't the increase uniform over the entire rpm range? Am I missing something?
Old 05-15-2012, 11:45 AM
  #55
I can't comment on the strength of the aluminum shaft vs the steel one and the vibration increase from using a longer 1 pc. shaft, keep the info coming guys who know more about it than I do. I'm learning a lot.
The increase in power at the wheels is from less rotational mass that has to be spun by the engine's power. How much power does it take to spin a straw between your thumb and index finger? Now what about a rod of steel the same size, how much power would it take? Same principle. If every part of the drive train were half the weight it is now, engine output would be the exact same but how much of that power output would make it to the wheels would increase dramatically. Reducing the difference in the dyno number between engine HP and wheel HP for every pound of rotating mass saved.
Old 05-15-2012, 01:13 PM
  #56
TVPostSound
Yes, thats another factor.
The power gain was most likely the diminishing returns of the gains.
Once the weight was overcome, there was no more gain to be had.
Newton's first law of motion.
Old 05-15-2012, 01:20 PM
  #57
Modme
Modme's Avatar
Originally Posted by SharpByCoop
There were 16 runs logged between the 'before and after'.
I'm certainly interested, too, but I'm curious about the forensics.
Coop
As Coop pointed out, there were 16 runs in between the before and after results. I'm wondering if the results were skewed by taking the lowest power run from the OEM driveshaft and the highest power run from the Z1 driveshaft.
Dyno results could vary by > 10whp from run to run. The correct way to compare the dynos would be to take the averages of at least 3 runs.
Old 05-15-2012, 01:26 PM
  #58
SharpByCoop
SharpByCoop's Avatar
^^^ Thanks for understanding and clarifying this. I'm liking the changes, but not completely believing the gains as shown.
Coop
Old 05-15-2012, 02:09 PM
  #59
indyn
indyn's Avatar
got mine two weeks ago but couldn't install it because Z1 sent me a MT version instead of Auto. Even though it said 'g3<del>5</del> 7 Auto' on it The aluminum driveshaft is really light once its out of the cardboard tube, disappointed that it couldn't be installed. We had to take the exhaust and shields and saw that the flange was different.
lighter wheels and improving drivetrain losses such as the driveshaft do show up at the lower band of the rpm and these gains negate with accelaration, but even with 16 runs, looks like there is lot of power to be gained.
Someone at Z1 has been using this driveshaft on their supercharged/turbo G35 with no issues.
But don't 370z and R35 come with one piece driveshafts from factory? Even if 370z is not considered because of the shorter length of the car, the R35 is comparably similar in length to the g37. So the one piece driveshafts are doing fine with one less joint.
BTW, there is a centre bracket on the g37 driveshaft which is fixed to the underbody of the car, the whole shaft behaves like one piece so there is no outward bowing or change in angle.
Old 05-15-2012, 03:11 PM
  #60
Gville37
Gville37's Avatar
newtons first law thats great. good ole middle school science books
Quick Reply: Z1 Motorsport Driveshaft B4 / After Dyno G35
