Z1 Motorsport Driveshaft B4 / After Dyno G35
Old 05-10-2012, 09:23 AM
ANMVQ
ANMVQ's Avatar
In for some more info on strength being Fi this would be something I would be interested in.
Linky $428 is nice but only otion is manual?
http://www.z1motorsports.com/g37_370...oducts_id=5711
Old 05-10-2012, 09:48 AM
ANMVQ
ANMVQ's Avatar
ok Called them , Very cool guys, Said the FI guys would have NO issues with this , The Company that makes them is one of the best in the country, But they have no Auto ones left, He said 2 weeks..
Old 05-10-2012, 09:50 AM
awais
awais's Avatar
Wow. Impressive torque gains in the midrange. Can you tell a difference in city driving?
Old 05-10-2012, 10:04 AM
Originally Posted by G37Sam
Is no one concered with the decreased strength?
A few hard launches on drag radials may beg to differ
Enlighten us Sam. What are your thoughts? Are you aware of the specs on the OEM shaft and this one as far as diameter and wall thickness of the tubing?
Also, has anyone who has this installed commented on increase in NVH?
Old 05-10-2012, 10:43 AM
Emillion45
Emillion45's Avatar
Would this work on a X?
Old 05-10-2012, 10:59 AM
Kidcane
Florida G Club
Kidcane's Avatar
These are plenty strong. They are stronger than a CF driveshaft and that is what a GTR comes with.
Old 05-10-2012, 01:03 PM
Staples
Staples's Avatar
I wouldn't worry about the durability with this. It's made to OEM specs and will hold up like a stock driveshaft, if not, it would be stronger. The reason our cars can't use a 1 piece is because it's made of steel (for certain safety reasons). A 1 piece steel driveshaft because of its weight it has a tendency to flex under load and would cause more issues then not. Aluminum and Carbon fiber because it's so light weight doesn't flex under longer lengths.
Old 05-10-2012, 01:09 PM
All of this affirmation of it's strength is fantastic. However, does anyone have any engineering info to back it up or just opinions? What's the OD and wall thickness of the OEM steel shaft and of the aftermarket aluminum one? Anyone have that? And I'm sure it's been posted somewhere before, but since this is a new thread, does anyone know the weight of each?
Old 05-10-2012, 01:18 PM
Staples
Staples's Avatar
I know the weight differences. OEM: 31.5lbs - Z1: 16.50lbs.
The aluminum has a diameter of 3.5", I'm not sure on the stock. I can measure it today since I know someone who has an extra one lying around.
The major reason behind the weight savings though is because you're alleviating 1 of 2 U-Joints. That's where most of the weight comes from, along with the fact it has more rotational mass behind it. The reason they use Aluminum is because it doesn't flex at long lengths and is a cheaper alternative to Carbon Fiber.
Old 05-10-2012, 02:11 PM
SharpByCoop
SharpByCoop's Avatar
Originally Posted by Staples
This is basically a before and after Dyno. Before the Aluminum Driveshaft was added (red line) and after (blue line).
There were 16 runs logged between the 'before and after'.
I'm certainly interested, too, but I'm curious about the forensics.
Coop
Old 05-10-2012, 03:09 PM
SwissCheeseHead
SwissCheeseHead's Avatar
What's the DIY rating on this? Difficult? Easy? I am also interested in "freeing" up power. That's always a good thing.
Old 05-10-2012, 04:31 PM
Legz
Legz's Avatar
Hmm the torque does look a little bit excessive
Old 05-10-2012, 04:32 PM
rAiN
rAiN's Avatar
just like anyother parts, unbolt, and bolt back in
Old 05-10-2012, 04:55 PM
  #29
ECain18
ECain18's Avatar
Very easy install. Took More time to take the heat shields and exhaust off than anything. 45 mins total.
Black betty: there isnt any more vibration or harshness, only a slightly louder hum when decelerating in 2nd gear is the only time i ever hear it
spinn (05-17-2017)
Old 05-10-2012, 05:14 PM
  #30
SwissCheeseHead
Nice. I didn't know if there were any seals or anything that needed to be replaced. U-joints and differentials make me a little nervous...
Quick Reply: Z1 Motorsport Driveshaft B4 / After Dyno G35
