Help Problems with VDC
Old 04-01-2012 | 05:18 AM
WalkNUDown's Avatar
WalkNUDown
Problems with VDC
With lowering your G with coilovers, will the VDC light come on (malfunctioning) and if so how to resolve this issue. Read this in the OEM manual.
Old 04-01-2012 | 05:26 AM
Rad_Slinger's Avatar
Rad_Slinger
Lowering the car doesn't really have anything to do with the vdc. If your vdc light is on and staying on until you shut off your car, it most likely has something to do with the brakes. Either your brake fluid is low, or your brakes are getting to the point where they need to be changed.
Old 04-01-2012 | 12:43 PM
Weiboy718's Avatar
Weiboy718
Op! If your toe is way out of wack it will trigger the VDC light to stay on. Did you get an alignment yet? If not, I strongly advise you to get an alignment ASAP.
Old 04-01-2012 | 04:49 PM
Rad_Slinger
I didn't know that.
Learn something new every day.
By trigger you mean wheels start to slip due to the alignment not being right, correct?
Old 04-01-2012 | 04:54 PM
Weiboy718's Avatar
Weiboy718
Originally Posted by Mattster
I didn't know that.
Yup. I know 2 guys who did a suspension install via diy along with the toe bolt. One almost didn't made it home because the toe was so out of wack and constantly kicking out his rear end. The other was smarter, he didn't drove on the freeway till he got an alignment. Both had their VDC light on solid.
Old 04-01-2012 | 04:56 PM
Rad_Slinger
Good to know.
Thanks for the enlightenment Wei!
butwhatuptho
10-04-2015 07:51 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
MrRiv
09-29-2015 04:59 PM
k19g37x
09-29-2015 02:46 PM
Quick Reply: Help Problems with VDC
