Building a 1000 HP G37
Alright so i found a F/I 1000 whp twin turbo but you must build you engine to the extreme to produce this much. So what exactly should I do to my engine before dropping the turbo in, any specific ideas and companies in mind?
You might find this to be informative...
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/t6bAZmEEIb0?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/t6bAZmEEIb0?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
but.... i'll play... just click buy now.
GTM Motorsports**POWER PACKAGES**GTM VQ37VHR 1000HP TWIN TURBO PACKAGE-M/T-GTR KILLER
50k no labor PLUS you would still need to do some work on the drive train... half shafts, rear end, diff, I know GTM included a new clutch but I but some of the gears wont hold up
Not to sound like a totally douche but, if you don't know what is required to handle a 1000hp twin turbo setup then you probably shouldn't be attempting this at all. That's just my .02
But if your serious; I would check with S&R Performance as they are know for big custom builds like this.
Its not that I dont know what to do I have turbo'd two of my other cars before but it was just to 465whp and 478whp never something this big I understand everything is needed to change just should I do a stage 3 or 4 everything because the drive train (clutch) stage 4 and 3 are stiff but thats probably the only thing that can work to maintain the power Im assuming.
Brian Martin (02-04-2020)
