Help Stillen Supercharger kit install HELP!
Old 02-19-2012 | 02:03 PM
martyg's Avatar
martyg
I just got done a 22hr install of the stillen supercharger kit and now it will not start. The fuel system has pressure and the engine spin when trying to start, but it will not crank. If anyone has any ideas or this has happened to them could you help. Thanks.
Old 02-19-2012 | 06:56 PM
Weiboy718's Avatar
Weiboy718
does the engine even try and turn?
Old 02-19-2012 | 07:58 PM
Modme's Avatar
Modme
Kinda conflicting yourself there. Crank = Spin. You mean it doesnt ignite?
Old 02-19-2012 | 09:00 PM
tech7's Avatar
tech7
So it cranks but doesn't start?
Old 02-19-2012 | 10:01 PM
martyg's Avatar
martyg
It doesn't even try to start. I tried to see if I could get good spark and I did, but when I tried to start the car with the plug out I couldn't smell gas being sprayed.
Old 02-19-2012 | 10:02 PM
martyg's Avatar
martyg
Yes it tries to start, but no combustion.
Old 02-19-2012 | 10:04 PM
Weiboy718's Avatar
Weiboy718
recheck your fuel pump. or at least turn the car to the on position and listen for the pump
Old 02-19-2012 | 10:30 PM
martyg's Avatar
martyg
Video of what I am seeing
Stillen install post install - YouTube
Old 02-19-2012 | 10:33 PM
Weiboy718's Avatar
Weiboy718
can you hear the pump at all?
Old 02-19-2012 | 10:40 PM
Staples's Avatar
Staples
Weiboy is right... turn the car to the on position but don't try to crank the motor. Listen for the fuel pump. The Walbros are pretty loud. If you don't hear a buzzing noise then the pump isn't installed correctly.
Old 02-19-2012 | 11:03 PM
martyg's Avatar
martyg
I hear the pump come on for a second or so when I put the in ACC on. And when I try to start it I hear the same buzzing sound. Should it remain on in the Acc on mode?
Old 02-19-2012 | 11:17 PM
Weiboy718's Avatar
Weiboy718
you should hear it continuously on ACC mode i think. is it cutting out?
another thing is. did you flashed your ECU with a new tune yet?
Old 02-19-2012 | 11:25 PM
Staples's Avatar
Staples
I just watched the video. You can definitely hear the fuel pump priming. I didn't know that you could actually try to crank the car. Like Wei said, you installed the UpRev ECU flash?
Old 02-19-2012 | 11:26 PM
martyg's Avatar
martyg
So it should be running all the time? if so I will take it apart and look. with the ACC only without starting it cuts out after a few seconds and when starting it goes on for a few seconds while trying to start. I did do the ecu reflash before trying to start. also before i even start the install i ran the car with the new pump for 5mins after the pump was replaced and it seemed to run just fine.
Old 02-19-2012 | 11:29 PM
Weiboy718's Avatar
Weiboy718
Originally Posted by Staples
It should be heard when the car is in accessory mode or when the motors running. I think I remember reading in the instructions that you have to splice and extend your MAF harness and run the heat exchanger pump? I'm willing to bet if it's not the fuel pump installation, it's going to be the heat exchanger pump or when the MAF harness was extended.
yeah, i kinda recall i hear my pump stays on while when on ACC.
i am pretty sure he extended those MAF wires, the heat exchanger pump won't have any impact from starting the car. that pump is only to circulate the heat exchanger coolant around. let's wait till what the OP say's.
Quick Reply: Help Stillen Supercharger kit install HELP!
