g37 revs limited?
g37 revs limited?
whenever i rev my g37 engine, it will only go up 5,000 rpms? is this normal and is there a way to un_limit the rpms so that it will go higher? seems kinda pointless to limit such a powerful machine
Just say no!!!!!
LOL.. What's the OP have in mind, redline the car, then do a neutral drop? Thus they limit it to 5Krpm under free revving conditions.
I used to ride with a bunch of people that would sit there and rev (at times to some very high rpms) their bikes at a stop light. Very annoying especially when they're running nearly straight pipes. Many times I wished they'd through a rod or spin a bearing doing this. Learn the lesson the hard way.
Edit. On the dyno, the engine is not free revving, the dyno roller is providing resistance to the drive wheels.
Mr. Drop it like it's hot
Just say no!!!!!
When you dyno a vehicle, you run from a low rpm (2-3K depending on the operator) up through redline. Some operators will stop accelerating just before redline, others bump off the rev limiter.
Pic below is from my bike, which hit the rev limiter at 11.5Krpm... Not bad for a little 1L engine
