Who has a Stillen G37 Supercharger? Numbers, pics, vids!
#841
Thanks for all the input guys and sharing your personal experiences. From my experience with other platforms and a twin turbo g35, you don't really lose power if you go with a well designed more free flowing exhaust path with forced induction. You may lose some low end torque, but make up for it in the mid and high range.
I gained about 15 whp with test pipes on a jwt TT g35. A buddy of mine kept ruining his Berk HFCs on his supercharged setup, but that was because he was running rich with his tune.
I don't want to go with test pipes for this car, so it's stock or HFC. I may just stick with stock if people are saying HFCs will go bad simply due to the high exhaust gas temperatures...
Anyone install high flow cats sometime after installing his supercharger? Power gains with a re-tune? Did the high flow cats go bad quickly?
#842
#843
Any bolt on ceramic core cats available for the g37, or will I have to have them welded on to some piping?
#844
#846
Wow, that's pretty amazing! Where in Texas are you located? I'm in DFW. I want to relocate my MAFs like you did and just use that same large filter directly on the supercharger. Do you have a part number or link for that filter?
#847
Filter: K&N RX-4130-1
Mad A (05-05-2017)
#848
Edit: but my MAFs have to go somewhere if I am ditching the stillen intake portion that goes into the blower... right?
#849
Thanks for the input. Now that I think about it, I'm going to get tuned by Seb, and he will tune it using their MAP sensor, so there probably is zero benefit from moving the MAFS past the blower anyway. Would you agree?
#850
He is correct, I started out with MAF relocation and upgraded to a 4 wire map sensor that has the IAT build in. I purchased it through Boost Logic in Austin.
#851
Ok, I've make a custom pipe and relocated the MAFS properly, where each sees 50% of the air flow.
My question now is as follows. I'm ready to put the filter directly onto the supercharger. The current silicone coupler has two hoses going in. On the driver side I believe is the hose feeding re-circulating from the by-pass valve, so I'm not concerned about that one. What about the one on the passenger side/left? What do I do with that once that coupler is gone and I just have the filter on?
#852
I put a filter on that tube. No issues with the tune or idle.
#853
#854
I picked up a little universal filter from advance auto part. I didn't buy a complete kit as it wasn't available for the Q50s so mine didn't come with a boot or intake tract.
#855
Maybe i should of started my on forum/topic but im thinking of the stillen sc but i wanted to know since my 08 g37s coupe just hit 110,000 miles on it with no major issue and all and most maintenance done would anybody still sc it. I really dont care just want peoples opionion and advice. Either way im getting this kit next year.
