i've never been able to get a clear answer - can someone recommend a weight for winter use? i use the oe weight currently. amsoil 5w30. i'm in seattle...it gets around 32 degrees but we're expecting colder climates.
It's all in the owners manual, infiniti recommends specific oil weights for certain temperature ranges.... and it looks like they say 5w30 for any given temp...LOL!!
Opposite extreme here, but about all I would change is run a 10W-30 in a Dallas summer, June-Sept. But as mikelr, stick to the "book" and you can't go wrong.
You won't lose any warranty fact is 0W-30 is much better for your engine when cold starting... I have the dealer pour in Amsoil SSO 0W-30 every oil change...
Wouldn't you "theoretically" have more residual oil sticking to the parts w/ a heavier oil so you'd have better protection at startup? Just curious
that was a great read - albeit i skimmed through it (i have a midterm tomorrow ). i've heard the same saying around from time to time. never really knew what to believe. what about on longer drives though? my gearing revs me a tad bit higher than the average g w/ 3.69's (~300 rpms higher). hm...
