Need help with boost gauge install
You would not be able to make boost and such a good torque number in the mid range if you had a leak. Let me guess... your boost is tapering off after 5600-5700rpms?? You have a restriction of some type on your intake. My car made EXACTLY the same numbers with the old intake.
Your tuner may have not been able to recognize this since it is not your a-typical issue with a FI application. Lets us know how you make out.
You're right mikelr, my boost is tapering off in 5k range. I thought it was weird that I was making good torque, but losing boost up top. My thinking was the torque curve came in early and stayed flat, while the boost would climb until a loose coupler or something made the boost taper off when the psi would get high enough. I tightened the Turbosmart bypass valve today, and it was already real tight. I also hooked up my boost gauge and fixed some things that were not to my liking because I paid a shop for the install. It was hard to see if I was hitting the correct boost after tightening some things down because my boost gauge isn't actually mounted yet. One hand on steering wheel the other holding boost gauge, kinda dangerous looking down and trying to hit full boost. The highest I was able to get on the gauge was 7 psi. I'm getting a leak test and getting on the Dynojet tomorrow to help narrow some things down. Oh yeah, I'm throwing that damn P0300 code too, That's another story!. I'm confident that I'll find out what's going on, and I'll take into consideration what you are saying.
So, I finally went to get a leak test done, and man I had multiple leaks! There was so much S**t the installer didn't tighten down. Im hitting 9-10 lbs now at 7000 rpms and the car pulls much harder and smoother. There are still some tuning issues to work out, but I'm still running safe at a 11.0-11.2 AFR at WOT. I'll be adding some youtube videos of my dyno session soon.
Here is a quick video of my car on the Dynojet after the boost leaks were fixed. Excuse the poor video quality of my phone. Final numbers were 353 whp and 308 lbs in my 5AT. 9-10 lbs was achieved when going to 7K. Car drives and feels 5x better without those leaks, However, I'm still not at the numbers I was hoping for (400 whp), but I confident I can get there with a better tune from a better tuner. Mikelr, did you hone and polish your intakes out yourself?
good luck and keep updating.
Yeah, my car runs a lot better than before. I'm waiting on tuner a from AMS to fly out here to Oahu in November to retune my car. If I still lived out in Cali, Vallejo to be exact, I would take the time to go visit GTM and have them work out my tuning issues. For now I'll just take it easy and be patient. I'll keep you posted.
I'll ask him about it, and see if there is something he can do. I can also just wait for the AMS tuner to get here in two months and retune my car. AMS tunes a lot of EVO's, GTR's, Porsches, some Nissan/Infinitis, but they are an Uprev Protuner with some solid experience behind them. Thanks for your help, and I'll let you know how it goes.
willstophe
14
09-14-2015 09:02 AM
Skeletor06
08-02-2015 12:54 AM
