eliminate lag?
eliminate lag?
anyone have any ways to help eliminate lag? i drive a 2010 g37x coupe and i just hate when i will pull up to a stop sign slow down and then when i try to speed up the car just wont go. or when im switching lanes and i am trying to speed up and once again the car just wont go. i have found that driving in sport mode helps a lot but i was wondering if anyone else knew any techniques to get rid of this. the car is unfortunately a lease so i cant really do any modding. thanks in advance!
You can dis-connect your battery over night to re set ecm... That should be done twice a year, anyways IMO... really worked for me, especially concerning trans performance... Also there is an aftermarket speed throttle sensor that's plug and play that I've heard good things about...GL
why would disconnecting the battery reset the ECU? and what benefit is there to doing that? Is it to eliminate any memory of driving style?
I got the tsb done for the transmission reprogram and hypertech. Still definitely feel the lag when coming to a slow down or stop and giving the gas again. Car jerks violently after like 1-2 seconds after depressing the accelerator pedal. Nature of the beast, I guess...
Diode Dynamics
Lighting/Cleaning Products
81
11-30-2021 02:28 PM
