Got My New....
Old 08-11-2011 | 12:56 PM
GraphiteG37S's Avatar
GraphiteG37S
About time you upgrade that clutch .. :-p
Old 08-11-2011 | 01:23 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
hehe, good question and i have the definate answer for you.
it's because i am a broke a$$ fool modding on a really low budget on top of that i probably don't need a twin clutch setup altho i wanted to get the SPEC Super Twins in the beginning and was convinced i didn't need it so that's why i leaned towards the Southbend setup which i can afford. there's actually quite a few people running their kit and got nothing but great reviews. whether it's the G forum or the Z.
we'll see what happens after it get's installed this weekend, i probably won't see it's full potential till it's completely broken into.
lmao! ...def give us feedback once installed!
Old 08-11-2011 | 02:05 PM
kRAM's Avatar
kRAM
Who are you having install this? I hate the stock clutch and i only have 17,000 miles on it. Just wanna change it already.
Old 08-11-2011 | 04:58 PM
Weiboy718's Avatar
Weiboy718
For sure, that probably won't happen till it's completely broken into.
if you're serious about it I can surely ask him.
Old 08-11-2011 | 05:01 PM
MyocyteX's Avatar
MyocyteX
actually, i got that too! it's in my first pic.
Oh nice! That's gonna be awesome! Enjoy!
Old 08-11-2011 | 08:08 PM
Z gave way to G's Avatar
Z gave way to G
Nice bro! Enjoy
Old 08-15-2011 | 11:36 PM
WPPJR30's Avatar
WPPJR30
Happy to hear that you got everything figured out, Eric. I'm glad to know that you will not be banging that thing into reverse doing 100MPH...
Old 08-15-2011 | 11:46 PM
Weiboy718's Avatar
Weiboy718
hey, it is scary knowingly i can possibly put it into reverse when going into 6th gear lol.
update!!! everything went in smooth except it took a good ol 3hrs just to bleed the clutch. it's probably because the heavy duty CSC that was playing a little hard to get lol. after a simple phone call to Joe@Zspeed we were able to tackle it within 45mins. first impression is the clutch is nice and smooth. power picks up a tad faster now due to the slightly lighter flywheel. the pedal is not heavy at all and is very daily driveable.
we installed the B&M short shifter at the same time and ran into a slight issue because the damn manual told us not to reuse the stock triangle plate. that plate is very important, it's there so you can't slide it farther than 5th gear and accidently into 6th gear. i just fixed it by installing the stock plate back on there and now is all good!
i'll update back later after some more miles has put into it!
Old 08-18-2011 | 08:46 PM
Aggieav8r's Avatar
Aggieav8r
subscribed for updates ... supercharging in December and curious to see how you like this clutch.
Old 08-19-2011 | 12:51 AM
Weiboy718's Avatar
Weiboy718
i like the clutch a lot, grabs pretty hard and i can feel it really supports my power. can't wait to fully break it in and redline it lol.
right now, idk if my lines still has air in it or not cuz the engagement point is sometimes high and low. pretty hard to get in gear. wondering if it's part of the break in process or not. if anyone here has similar setup with the Zspeed CSC pls chime in
Old 08-19-2011 | 11:00 AM
GambitX's Avatar
GambitX
Yes sir, you gotta bleed and bleed that CSC. We had the same issue with mine. Finally after rebleeding it and adding Motul 600 its back to 100 percent normal
Old 08-19-2011 | 11:25 AM
Weiboy718's Avatar
Weiboy718
Yeah, thanks. That's what I'm planning on doing after work today
Old 08-25-2011 | 09:09 AM
ECain18's Avatar
ECain18
hows your b&m, does it rattle? Or are do you still have to baby it a bit for the break in. and also, w/ using the stock triangle plate, does yours go past 5th at all? Like mine has a good inch that it can go by 5th, and its somewhat difficult to pick 5th up because of that
Old 08-25-2011 | 09:27 AM
  #29
Weiboy718's Avatar
Weiboy718
my shifter does not rattle to my surprise. I did one thing differently from what b&m instructions says. On The stock shifter there's a rubber triangle boot, I removed it from the stock and installed it on The b&m. That piece dampened out all the noise coming from the transmission. TRy it out.
The reason why your 5th and 6th gear goes past it is because your lockout plate is adjusted too far right. WHat you wanna try doing is put it into 5th gear and adjust the plate so it touches the lock out pin then tighten down the screws. Make sure you can get into all gears smoothly before tighten it tho or else you'll have to redo it
Old 08-25-2011 | 09:34 AM
  #30
ECain18's Avatar
ECain18
thanks will do ill let you know how it works. Got a bunch of stuff to install coming up so ill do it when i start working on that
