need my bearings replaced can someone give me info on this
hey i need my bearings replaced for awhile now and im just curious as to how bad it is to drive with them broken and if itll break anything else. im getting it fixed under warranty but its either infiniti has no appointments or im too busy to make it to an appointment. if it wasnt under warranty i woulda had my mechanic fix it already but its damn expensive out of pocket. my only worry is am i ****ing anything else up driving on it?
At worst, you'll destroy your hub, but that should also be covered under warranty if the wheel bearings are bad.
+1 to breftayka Bad wheel bearings could destroy the hub, spindle, tires, and a few more things if they actually fail.
Your alignment will be off & constantly changing too. And since you apparently missed appointments for the repair I doubt the dealer would cover any additional damage.
