Uprev ecu questions
Uprev ecu questions
Does anyone know if installing an uprev tuned ecu from another G37 would cause any issues? I have almost identical modifications on my car compared to the car with the uprev ecu. I think the only difference is the owners car has different intakes than I do. The owners exhaust setup is identical to mine, same brands and all.
What are the risks if any with this kind of ecu swap?
I honestly wouldn't. ALL cars are different, that is...unless your tuner tuned based on numbers and not per the individual car. I don't know the logistics, but I would assume UpRev to be clever enough to prevent such things (licensing issues). Save up, and get your own custom tune.
From what I understand the current owner did have the car on a dyno when the ecu was tuned, so it was custom. I was hoping someone would be able to tell me if the tuned ecu's were transferable, meaning that I could take it to an Uprev tuner and they would not try to charge me more than just doing a custom tune.
Do not just put it in and expect things to work, the whole point of custom tuning is that it's specific to your car so if you take someone else's custom tune and put on your car, it will not work well (and may even cause problems)
The uprev "ecu" is just a flash of the regular ECU with their custom maps. So if you take that ECU (and don't forget his cable!) you can switch it over to your new car and then get a new custom flash for YOUR CAR.
Am I thinking along the correct lines here?
