Mazworx-GambitX Greddy TT build
Old 09-10-2011, 02:34 PM
  #106
TVPostSound
TVPostSound's Avatar
Originally Posted by GambitX
the car was only running 8psi, we are still trying to figure out what went wrong. So far 2 bend rods
TT on a 11:1 compression ratio engine is dangerous.
I personally wouldn't try it, unlees it's 9:1 or lower.
Engine timing is crucial.
Also no one has been able to crack the VVEL, that could be another issue.
Old 09-10-2011, 07:51 PM
  #107
Staples
Staples's Avatar
The VVEL system has been out for over 3 years without any issues except for Valve Overlap in terms of boost. The rods (weakest point on VQ motors) are beefier then the DE, Rev-Up, HR motors. It's all about the tune.
Old 09-12-2011, 12:13 PM
  #108
GambitX
GambitX's Avatar
I picked up the car last wed, drove it 100.1 miles home with zero issues. The alignment was out so I drove it straight to the shop by my house. The car would not start back up after literally 3 mins after shutting down. Its not at a shop in tampa trying to figure out what is wrong, NO check engine, No codes, still so lost why its not starting.
Car starts up for 3-4 seconds at idle and shuts off as soon as you hit the gas. Sometimes it will rev and then shut down.
As you guys can tell im kinda over the car already.
Old 09-12-2011, 12:58 PM
  #109
Abdiel
Abdiel's Avatar
so it starts and idles but shuts down immediately or very quickly after pressing accel pedal? or it doesn't start at all?
Old 09-12-2011, 01:23 PM
  #110
GambitX
GambitX's Avatar
it starts everytime, just wont stay on longer than 4 seconds and if you hit the gas it will 90 percent of the time shut off or rev with no problem and then shut off
Old 09-12-2011, 01:54 PM
  #111
Kidcane
Florida G Club
Kidcane's Avatar
Where is it now? S&R?
Old 09-12-2011, 03:10 PM
  #112
Abdiel
Abdiel's Avatar
low oil pressure? bad oil pressure switch?
Old 09-12-2011, 03:35 PM
  #113
GambitX
GambitX's Avatar
car is running! they found the a line inside the gas tank had come off the regulator. Car is 100 percent again
Old 09-12-2011, 07:13 PM
  #114
superchargedg
superchargedg's Avatar
Good news for once
Old 09-12-2011, 07:34 PM
  #115
08_g37s
08_g37s's Avatar
i bet when they found out it was something easy for once you wer happy
how is she driving ??is it a smooth power curve?
Old 09-12-2011, 10:29 PM
  #116
GambitX
GambitX's Avatar
yes! WOW it was a huge relief that it was something simple but I still had to pay for man hours on the car. Owell, its done its back in my garage for the first time in almost 4 months.
Car drives like stock, very smooth until your in boost and all you hear is open wastegates. Its running on the factory wastegate springs so boost is max at 5lbs.
Im going to drive it alittle more this week but so far its very smooth and fun to drive. The clutch is loud as hell but I guess thats something ill get use to.
Old 09-13-2011, 12:55 AM
  #117
Kuro
Kuro's Avatar
Congrats with you man
Old 09-13-2011, 10:58 AM
  #118
GambitX
GambitX's Avatar
its good to open the garage and see it finally after 4 months. Im trying to get the days off to go to Z1 nationals and there have it retuned
Old 09-21-2011, 05:35 AM
  #119
G37Sam
G37Sam's Avatar
Glad to hear that she's running smooth!
What are your numbers like at 5 psi?
Old 09-21-2011, 09:57 PM
  #120
GambitX
GambitX's Avatar
Well todays update is a solid one, drove up to Z1 lastnight and had a few issues getting to them. Long story short I was able to get to them and had ZERO sleep.
Today we retuned the car with over 50 dyno pulls tunning the car from 400hp all the way to 525 at 11psi. Airfuel is 11.2 solid throughout the RPM band. Low boost setting is 8 Psi 469 hp sorry dont remeber the tq. 11 psi setting will be the high boost and the final numbers were 525hp/455tq
Im going to dl pics and videos when I have a chance
BTW Z1 guys were amazing! They were slammed getting ready for the Z1 nats and worked on my car like as if it were gold. Everyone there was a pleasure to chat with also.
THANK YOU Z1
Quick Reply: Mazworx-GambitX Greddy TT build
