Knocking/Pinging on an 08 coupe
My g37 coupe constantly knocks and pings, and has been doing so since I got it as a cert pre owned. It mostly does it when engaging the clutch in first gear. I never not use premium fuel, so what can be done to stop or avoid the knocking/pinging?
Mike
Mike
he said he never not use premium........double negative + improper english = he uses premium
considering he got it pre-owned, its possible the owner before him didnt use premium
I'd take it to the stealership before it becomes a kaboom.
I suppose you could disconnect the battery for 5 minutes to reset the ecu and see if that resolves it. Could just be an ecu glitch.
You aren't running aftermarket intakes or anything like that are you? They can make the car run lean (usually not a problem, but there's always exceptions)
superjoey
31
03-22-2023 11:56 PM
