Transmission Issue!
Old 06-03-2011 | 12:56 PM
Kimberley's Avatar
Kimberley
Transmission Issue!
My G37 is a 2009 and there is a problem with the transmission, this morning I couldn't get the car over 40 miles an hour and it was going up to 7,000 rpms. I have 61,000 on it and called Infinity in Valencia Ca. They told me it was no longer under warranty. Any ideas out there?
Old 06-03-2011 | 02:06 PM
G37SBS's Avatar
G37SBS
that sucks... i guess you have to pay out of pocket.
Old 06-03-2011 | 02:07 PM
sonicloud's Avatar
sonicloud
Your warranty should cover everything except wear and tear till 2013; don't let them fool you.
Old 06-03-2011 | 02:18 PM
IcebergG's Avatar
IcebergG
This may be a silly question, but is it a 7AT or 6MT?
Old 06-03-2011 | 02:38 PM
TVPostSound's Avatar
TVPostSound
Thats BS
Page 4 and 5 of your warranty book.
If you dont have your book, its published at Infinitiusa.com
2009 Warranty:
POWERTRAIN COVERAGE • The Powertrain coverage period is 72 months or
70,000 miles, whichever comes first. • This warranty covers any repairs needed to cor-
rect defects in material or workmanship.
TRANSMISSION AND TRANSAXLE - Case and all internal parts, torque converter and converter housing, auto- matic transmission control module, transfer case and all internal parts, seals and gaskets, clutch cover and housing, and electronic transmission controls.
Take it to Infinity of Thousand Oaks
Old 06-03-2011 | 03:40 PM
G37SBS's Avatar
G37SBS
so Powertrain coverage includes Transmission and Transaxle?
Old 06-03-2011 | 03:53 PM
TVPostSound
Of course!!
"• Powertrain coverage includes components listed below, supplied by NISSAN, except for those items listed under the caption “WHAT IS NOT COVERED.”
ENGINE - Cylinder heads and block and all internal parts, rocker covers and oil pan, valve train and front cover, timing chain and tensioner, oil pump, water pump and fuel pump, fuel injectors, intake and exhaust manifolds, flywheel, seals and gaskets.
DRIVETRAIN - Drive shafts, final drive housing and all internal parts, propeller shafts, universal joints, bearings, seals and gaskets.
RESTRAINT SYSTEM - Air bags and related electronic control systems."
redlinernyc
02-29-2016 11:06 PM
mcgrible
21
10-27-2015 07:14 PM
coachdave2001
09-21-2015 12:05 AM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: Transmission Issue!
