Dirty Rear Differential Fluid?
Old 05-15-2011 | 09:16 PM
eksigned's Avatar
eksigned
^ you can see it in the picture. top right of the pumpkin. as long as the car's level, it's literally impossible to overfill.
Old 05-15-2011 | 09:57 PM
Originally Posted by spect2k
Is there a DIY for this on the forum somewhere? I'm sure it's very simple and I can see the drain bolt from the picture above. Where is the fill bolt?
Take look inthe DIY forum stickies.
Old 05-16-2011 | 01:27 AM
dkmura's Avatar
dkmura
Originally Posted by soundmike
The fluid that came out of my differential was rather dirty, stank pretty bad, too. It had about 30k on it.
Actually, brand-new diff fluid will have that particular odor too. That lubricant uses pressure additives to handle the forces that diffs typically encounter. If you look closely at the used diff fluid that is pouring out, you'd find it still looks amber. Not like used engine oil at all.
Old 05-16-2011 | 09:13 AM
penciltop99's Avatar
penciltop99
Thanks all for the feedback. I'm going to look into changing the fluid myself.
Old 05-16-2011 | 08:47 PM
soundmike's Avatar
soundmike
New fluid does have an odor, but it certainly wasn't as strong as the used stuff that came out.
Here you go.
gshack » Rear Differential Oil Change
Old 05-16-2011 | 11:46 PM
TinsleyC's Avatar
TinsleyC
Originally Posted by penciltop99
My owner's manual was stolen out of my car so I can't look it up...
You can download one here. Makes searching easier as they are text-searchable PDF's.
Infiniti Ownership | Manuals & Guides | Infiniti USA.
jasec (08-27-2016)
Old 05-17-2011 | 09:03 PM
spect2k's Avatar
spect2k
Here you go.
Thanks, that's useful! It looks pretty simple.
Old 05-18-2011 | 07:51 PM
blkdragn's Avatar
blkdragn
Did this back at 60k. I used Royal Purple though.
Old 05-20-2011 | 09:38 AM
speedster100's Avatar
speedster100
Had an Infiniti/Nissan dealer tell me at 20000km that mine needed to be changed as it was dirty. I politely said no thanks and have never went back to that dealer.....
Rip off artists are everywhere...
Old 05-20-2011 | 07:00 PM
Presto's Avatar
Presto
what diff fluid do you guys use?
motul gear 300 or 90PA?
Redline 75w90 or 75w85?
Old 06-10-2011 | 06:30 PM
GSoccer24's Avatar
GSoccer24
I did mine last weekend at 50,700 miles and the fluid was greenish brown, a little milky, and a lot of tiny particles flowing out. Never seen diff fluid like that and thought it was really weird. Refilled with Redline 75w90.
Old 06-21-2012 | 07:50 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Bear in mind that only the 7AT/2WD models are specd for 75/90, everything else (incl. AWD) gets 80/90 in the differentials.
e3phung (09-03-2016)
Old 10-19-2012 | 04:26 PM
BigcatG37s's Avatar
BigcatG37s
Hi,
Yes I have the same experience. They checked it after oil change and stated it was low. Est cost about 90 bucks. It provides lubrication for the gears and prevents metal shavings, metal on metal contact, etc. Not to take lightly and forget about, as that can turn into a broken axel.
Hello,
I took my car into the local Infiniti dealership today for an oil change and I was told that I have dirty rear differential fluid that needs to be replaced for about $80. Does this sound legit?
I have a 2010 G37 Sedan w/ about 29000 miles.
Thanks!
Old 10-19-2012 | 06:40 PM
  #29
00Max00's Avatar
00Max00
$80 sounds like a good price to me. I don't know how they determined it was dirty though.
Changes were they never looked at it.
Old 10-19-2012 | 06:42 PM
  #30
00Max00's Avatar
00Max00
Originally Posted by BigcatG37s
Hi,
It was low? Sounds like you have more trouble than just metal shaving in the oil. You got leaks somewhere. If you never seen oil on the floor, elves must have taken it.
Quick Reply: Dirty Rear Differential Fluid?
