Normal to grind into second near redline, or did the prev owner bork my tranny?
Old 05-04-2011, 02:23 PM
BagFalls
BagFalls's Avatar
Originally Posted by Gee37S
Just left the dealership. Test drove it with the tech and he thinks it might be related to the short shifter. I'm going to remove it and see if it resolves the problem. If it doesnt, they'll then order the new parts.
Sounds pretty promising.. I'll believe it 100% when they give you a new tranny or rebuild your existing one...
Old 05-04-2011, 02:41 PM
Gee37S
Gee37S's Avatar
lol I'll probably get it off the car this weekend. As soon as it grinds again I'll give them a call to schedule an apt! I'll let you guys know what happens.
Old 05-04-2011, 05:26 PM
1NEETO
1NEETO's Avatar
Synchros work the hardest at high rpm's. If it grinds ejem shifting fast at high rpm's then you can be certain that synchro is wearing out.
As for the noise. Does the noise happens when you press the clutch pedal or when the pedal is released?
Old 05-04-2011, 05:36 PM
BagFalls
BagFalls's Avatar
It happens on release during that little bit of slip while you are letting the clutch out. It happens in all gears
Old 05-05-2011, 01:32 AM
Gee37S
Gee37S's Avatar
Noise for me happens when the clutch is fully pressed against the floor and I'm putting the shifter into 2nd gear. There is a resistance as I try to put the shifter into 2nd accompanied by an obvious and audible grind.
Old 05-05-2011, 03:14 AM
1NEETO
1NEETO's Avatar
Wish could hear the noise. But rule if thumb is that if there's a noise when the clutch pedal is pressed that means the TOB is going bad. If the noise comes when you release the pedal then it's the input shaft bearing. Anywhere in between could be anything from the flywheel, pressure plate or disc.
Old 05-05-2011, 01:13 PM
BagFalls
BagFalls's Avatar
Thank you. This was informative. I knew TOB was normally noise on the press in, but I didnt know it was the input shaft for release.
Same here, man. 1NEETO was discussing my other transmission issue with me. One is the 2nd gear synchro. The other is an input shaft noise in every gear on engagement.
Fingers crossed my dealer is feeling generous on monday.
Old 05-10-2011, 10:53 AM
BagFalls
BagFalls's Avatar
In case you were curious, I was at the dealer yesterday, and the service manager couldn't replicate the synchro issue. I was afraid to tell him I really have to push the car hard to get it to grind (didnt want him to cry abuse)... guess I'll live with it for now and slow down my shifts a little bit.
They found out the clutch had been swapped by the previous owner at 21000, so I'm just waiting for them to void my powertrain (or just tranny) warranty.
Old 05-10-2011, 11:22 AM
Gee37S
Gee37S's Avatar
Oh damn that sucks. My car was acting like a freak yesterday, going into semi-limp mode but with no check engine light... don't know if it's related. Also had an issue last summer where my car would rev all alone lol. This thing is getting kind of scary now. I've got both those incidents on tape I'll post them when I get home.
Old 05-10-2011, 11:26 AM
breftayka
breftayka's Avatar
Why would replacing the clutch void warranty? The clutch is a "wear" item. They don't void your engine warranty for replacing oil, or the brakes for replacing the pads.
Old 05-10-2011, 11:32 AM
BagFalls
BagFalls's Avatar
Very valid points. I'll definitely bring those up should the situation arise. I'm expecting a call today regarding my other issues, but for now they are leaving the tranny alone because the noises it makes are "normal." I might record them and get a second opinion from the forums.
drewfinity
11-27-2016 02:11 PM
redlinernyc
02-29-2016 11:06 PM
cyberone28
09-23-2015 01:56 PM
inspector94
09-08-2015 12:57 PM
Quick Reply: Normal to grind into second near redline, or did the prev owner bork my tranny?
