Spark plug question
Those will work perfectly as an OEM replacement. They are Iridium plugs so they should last longer than platinum ones. Changing to a different brand than OEM wont have any "side effects" just as long as it's the right application. And NGK plugs are just fine in our cars as well.
Sorry for this bump from the past, but this should be corrected!!!!!!
Regardless of whether you can bolt them in or not, those plugs are a full two heat ranges hotter** than the OEM plug. Why on earth would you want to run hotter plugs in a high compression engine? (you'd be knocking like crazy!)
If you want to run a different brand plug, that's fine, but for god's sake at least get the right heat range!
** http://www.densoproducts.com/learnin...nversion-chart
A Denso 22 heat range equates to an NGK 7 heat range, not 5!
footballmania32
09-04-2015 02:17 PM
