No gear number shown when initial shift to DS
How come when you shift from automatic to sport mode, it doesn't show what gear you're in, but rather just says DS. It'll show once you shift up or down, but shouldn't you know what you're in immediately upon shifting? Weird!
Not to sound like a broken record, but if you were to read your manual, it clearly explains this.
DS is Drive Sport, not manual mode. Manual mode is NOT sport mode. Essentially, there are 3 different modes... D, DS, and M. Moving the stick over to DS does not put the car in manual mode.
Again, if you read your manual, you'll learn a lot more than what I could ever spew out in a few minutes.
It will go to DS (sport mode) first then once you shift it'll go to manual mode. You can hit the paddles and it will be on manual for a bit of time. Then it goes back to D.
so if i switch over to DS and then do nothing, will the car automatically shift gears on its own as I drive? I assume this "sport mode" is just a sort of a more aggressive ride? Obviously, when I then shift up/down, it goes to manual, right?
Drop A Gear and Disappear
D - transmission computer will select the gear that results in the best compromise between power and fuel economy, biased toward fuel economy.
DS - transmission computer will select the gear that results in the fastest acceleration, with a slight reduction in fuel economy. I'm not sure if it quickens the shifts or not.
M (manual) - you can select and hold any gear you like, as long as your gear selection won't lug or overrev the engine. When you come to a stop, it automatically downshifts back for you
37
10-17-2020 11:12 AM
delfinparis
11-16-2015 02:26 PM
Jonesmeister11
09-27-2015 08:28 PM
