Full synthetic to Partial Synthetic - is ok?
I've got a 2010 G37x Sedan, and when I went to my dealer for my first Oil Change, he didn't have Partial Synthetic, only Full Synth, so after bantering back and forth with him on if it is safe to go from Full Synth back to Partial Synth (I bought an oil change plan fro the dealer that stated partial Synthetic) I had him do the oil change.
Any problem with doing that this once?
I bought the car as a demo with 6k on it. I had the oil changed at 7500 with the Full Synth.
There's absolutely no reason at all that you need to use full synthetic unless you are doing extended oil change intervals. Eneos 5W30 is not a "full syntetic" and I've been using it for over 40K miles doing extended OCI with great results. And I've posted the UOA that backs this up. Most people telling you to use full synthetic are also changing oil way more often than necessary (extended oil change intervals is the only reason to use synthetics) and throwing money away.
Don't you guys remember my post a while back?! I'm offended.
According to the Infiniti, full synthetic oils can damage the engine (supposedly). Something about seals and some mumbo-jumbo. Partial-synthetic is what comes in the engine from the factory; it's recommended. Then again...I highly doubt any enthusiasts (ALL OF US!) abide by it. I sure don't...amsoil love
There is zero danger to the engine by using full synthetic oil, partial synthetic oil, or conventional.
You see I also have been hearing so many things...its good, its bad, do this, dont do that, I'm not quite sure who to listen to anymore...Not just on this thread or forum but pretty much anywhere where cars are the topic lol...That being said... on another thread, someone mentioned it was good to change the oil after you put your first 100 miles on the car in order to flush the oil from the factory containiments and other particals ect...so when I do change the oil (Im at 95 miles atm), is it ok to put full synthetic from the get go or should I just get regular 5w-30 oil and be done with it?
G-DOG
As far as at what mileage you should first switch over to a full-synthetic, most people are probably going to say to wait at least until the first scheduled oil change interval (3750 miles), but I’m sure you’ll get lots of different opinions on this.
^ didn't our cars come with break-in fluid? the point of it being to wash out and properly break in new, vital engine components? it's best to wait, assuming you go fully synthetic, especially on a new engine. you're throwing away good (expensive) oil when/if you swap out the break-in oil too quickly. helps flush all the metals from the break-in period.
37
10-17-2020 11:12 AM
