Performance after transmission software update
#31
Got the 7AT reflash done on my 2010 G37xS in late March 2011. Have 14,000 miles on the car.
I am mixed about the reflash ... previously, the speed of upshifts was not quite as quick as I wanted in all conditions (I had a 2008 G35xS before). Now it's a mixed bag - under light to medium throttle, there is an annoying lag shifting from 2-3 and 3-4 - like it holds the gear a bit longer, but then the actual gear change can be characterized as very lazy. However ... when you're on the throttle more, I get great crisp gear changes that are a definite improvement prior to the reflash. I now drive in DS mode much, much more often now. It holds gears a touch longer lending to the torque converter locking up sooner, and helping to give me those quick and crisp gear changes I like.
Re: Feeling slower or quicker ... Prior to the flash, I always felt there was some type of "resistance" in the 7AT especially in gears 1 and 2 - even when really stepping on it. Now, that "someone poured molasses in my tranny" feeling is over. The car is much more lively off the line and freer flowing in gears 1 and 2. I remember one post on here ... a member saying "DS is power mode - try it!" Now that makes sense to me - I can really feel the difference off the line between D and DS - love it.
Re: the "stoutness" and longevity of the 7AT ... I drive this thing like a bandit, and use the paddle shifters as if they are going out of style ... in D and in DS-M mode ... upshift ... downshift ... upshift early ... upshift then downshift ... double upshift ... double downshift ... and mostly under hard acceleration or quick deceleration ... I don't think this thing is going to break any time soon. The 5AT in my 2008 G was not nearly as tough ... This 7AT is definitely very, very stout. No other tranny I've had has been able to withstand my right foot or manual shifting like this car.
Re: the 3-4 surge ... still there, but greatly reduced ... and as another member pointed out it is when the car is re-started not too long after it's been sitting ... or when the tranny is not as warmed-up as the engine.
Hope this helped somebody ....
#34
I am not sure if my case is somewhat different but here are things that I have noticed since the tranny reflashed about three weeks ago:
1) In the lower gears (1-3), it feels heavier than before and makes alot more noise than before (the RPM goes to 4k now to upshift. Used to change the gear at below 3K);
2) It feels like the car became a 5AT now as I find the 5th gear is at over 60 miles (highway) and at around 35 miles (in the city). I wonder if it ever goes to 6th and 7th in the D mode.
3) Like others mentioned, mileage got worse in the city AND the Miles to Empty in the navigation became incorrect after the reflash (it used to be somewhat spot on based on the MPG displayed).
Is there any place to see what changes the new software was supposed to make?
#35
The flash is by far not perfect, but I feel that it is a signficant and worthwhile improvement for me.
1. The clunking down low (at low speeds) is nearly gone
2. The flare is there, but does not seem as bad
3. Less "confusion" on gear selection and less "slapping" into a gear with a big judder...
4. Easier to drive in stop and go traffic.
5. Does not feel 'heavier' or 'less spirited'... it feels just as quick as I remember it to feel.
I did not, and will not, do an ECU reset.
We'll see.
We'll see.
#36
#37
hadokenuh, absolutely.
I will say that with the Temps outside a little better (higher) in the NY area, the past 2 days, the car has perfromed better, much closer to what I expect - less hesitation, less gear hunting, seems to be in the right gear in all driving scenarios. It seems that the outside Temps do affect it, just as the Service manager said. I am speculating, but from reading on this thread and the other major Thread about the Transmission, from what I remember from various posters, many of the "satisfied" customers both before and after applying the TSB Reflash, were from Warmer Climates??? - Cali, etc...some didn't have the 07 G35X to compare to as well....
#39
I had the transmission flash done to my 2010 G37s several months ago. This has not changed much in the way of the driving experience, there is still a flare in the way the car up-shifts. But the main problem i have is when i am driving on the highway; cruising along at 60-70 and I need to accelerate quickly, there is a big lag. The car seems to wait a few seconds, hunt for the right gear and then there is an acceleration surge. I am concerned as in certain situations, this can be dangerous.
I traded my 2003 Nissan Maxima SE for the G37 sedan and the Maxima's transmission actually seemed more responsive.
Do other people experience this lag when trying to accelerate while cruising along at 60-70 mph? I seem to experience this in both D and DS modes (less in DS thought).
I hope that Infiniti can come up with a solution to this as the G37 is the best choice in this class (minus these nuances).
#40
^Almost the opposite for me. Cruising at 70 and coming up on a vehicle in the middle lane, with another car coming up at maybe 72 in the left lane, when I floor it to shoot out left and swing back into the middle, I often find myself doing 95 when I back off and slide back to the middle. No lag at all, the car explodes into acceleration.
According to my dealer, my car was delivered in Feb with the firmware rev from 10-075.
#41
Thanks for the reply Mudgen
#42
#43
Thinking further about what you described, it's very similar to what it feels like when the VDC kicks in when you're trying to accelerate out of a corner at the limits of adhesion. In a quick acceleration/lane-change scenario, you probably have your eyes on the road, not the dash, so you may not know if the VDC is lighting up. You might try switching it off some and seeing if you can rule it out as a cause. VDC _shouldn't_ be activating in those situations, but if it's somehow fooled into thinking there's slip, it could.
#44
"According to my dealer, my car was delivered in Feb with the firmware rev from 10-075."
But there have been two additional reflashes since that one, IIRC.
