Fuel Mix Up
I ran regular in my car once. It started knocking real bad and then it started pouring out blue smoke. Then the electrical system got all messed up - I couldn't change the channel on the radio, couldn't adjust my mirrors, I even got locked out of my car because the locks wouldn't work. And to top it off I got a flat tire. I looked like Chitty Chitty Bang Bang driving down the street. Then I went to Shell and put in some Premium and 5 minutes after I started my car all of the problems disappeared. Never put regular gas in your car.
Hi, exxon mobile screwed me. They put the premium gas in the middle and it's usually the last one, but 87 was the last one so by the time i realized, I had already filled it which is about14gallons of 87 and have maybe about almost 1/4 of premium gas to begin with before i started pumping. Will this harm my engine? Is there something I can buy to clean out the tank or engine before I pump on the next one when I am on empty? PLEASE HELP!
Drop A Gear and Disappear
guess you didnt read though all the post!!!
Talking about gas, what brand of gas do you use ? What I have noticed is that ANYTHING other than Chevron's premium feels off in my car. I can honestly notice a difference between Chevron vs Shell, Texaco , Costco etc..
Anyone else?
Anyone else?
By the way - Costco's gas is equivalent to Arco gasoline. Edit: Costco gas = Arco gas (Arco distributes to Costco).
I had been using BJs gas (similar to Costco) all the time on my vehicle...I switched to Shell V Power recently and found a biiig difference in terms of gas mileage and performance....Performance might be in my head, not sure, but definitely gas mileage went up by atleast 2 mpg....I recommend Shell...
