ATTESA VS Quattro (ATTESA haters learn your powertrains)
So I dumped my Audi TT Quattro for an 07 G35X. I have seen quite a few posts with haters saying Quattro is better. The correct answer is which type of bias you prefer. Quattro is mainly on fwd cars from VW and Audi. Very few cars VW/audi makes are RWD biased. ATTESA is on RWD cars. So to begin. I original worked on my cars as a hobby. When I bought the Audi it became a full time job. Every Audi should come with the service manual because its just a matter of time till some thing else breaks. You can almost count the time saying shouldn't something break soon. The nice thing about FWD bias in the snow is, you will get under steer and when the awd kicks in you get some over steer to keep the car going where you point it. With ATTESA you have oversteer and hope by the time the front tires kick in your not to close to spinning out of control and can pull you back in the direction you want when the front tires kick in giving some understeer back. Audi typically uses a haldex unit to engage the rear tires. This unit has its own oil pump, clutch pack, and filter. At $180 a pop at the dealer to service every 30k miles thats a downside. Both systems have about the same delay before they go awd but the ATTESA's snow mode allows you to lock in 4 at dead stops. This gives you a little bit more of an edge when making turns to launch on busy roads especially in the rain. In the snow both systems are virtually useless with traction control on. When you turn traction control off driving is a lot easier in snow especially the deep stuff. With traction control on the car it prevents wheel spin fighting the use of the awd trying to keep it in 2wd. After the awd is engaged both systems feel same. So which is better that depends on your prefernce of frt or rwd. I personally like the fwd bias because when your on clover leafs at 125mph and start to under steer off the ramp the rear tires would kick in giving the little extra oversteer to keep the car turning instead of shooting straight off the road. If that is not enough then you can trail break it and save yourself with ease. In the G you have to be more careful if there is a wet spot or sandy spot the rear tire can break loose producing a crazy over steer. This is why you mostly see RWD cars off the road or into trees when it snows. Once the rear end starts to swing you better hope those front tires can really hook when they kick in. Of course if at higher speeds the G would let you lock in awd this would not be an issue.
225hp 6 speed The wonderful F'ing engine that has a plastic water pump that would have its impeller crack and break off the pump shaft leaving you stranded nearly every 80k miles. Even the dealer charges a core charge for them which I thought to be odd to at a dealer. They also use a fail safe thermostat which will eventually fail and you will find out thats it failed when it gets cold and your freezing with no heat. There really isn't enough server space here for me to finish telling people how much Audi sucks. Thats why consumer reports rated them the lowest in quality. I decided to get rid of the Audi when they charged me $11 at the parts counter for a peanut turn signal bulb. If your going to make garbage cars then don't rape on parts just because its an AUDI. There were also other parts that I overpaid for and got sick of it. Thats my opinion. My previous car before that was a 90 eclipse GSX and I wish I could buy another that thing was a tank and full time awd.
Used 2002 Audi Tt 1.8T Chicago Arlington Heights IL - Sullivan Buick GMC - Call Us Now at 847-392-6660
Here is a link to my old car which is still for sale at the dealer
![](/images/banned.gif)
![](http://i52.tinypic.com/whjr6e.jpg)
You got 45 degree banked cloverleafs there or what?
I wanted an Audi TT Quattro Cabrio for the longest time, but I ended up buying the G37x instead. The TT is one sexy car but too bad they dumped the 3.2L engine and the AWD is part-time and front-wheel biased.
Knock 600 pounds off your car, then go around a turn. You would be surprised how much faster you can go.
Yes the A5 is a different system and a totally new car. This is one of the few systems that is rwd bias. Where as most people have A4 or Jetta's. You are also speaking of the latest and greatest Quatrro system that just came out. It gives more a rwd bias. Virtually all systems people are familiar with are fwd. The older systems worked as stated.
The tune in the system was still made by audi's vehicle dynamics department.
To hold 125, I need a 800' radius turn (yes, 800 feet, not a typo) and a 14 degree banking. How do I know that? Because I'm flat through the whole turn at roughly 2.4 lateral G's.
Cloverleafs around here are roughly a 125-150 ft radius?
