Help Clutch Install
Clutch Install
So I just had my JWT clutch and flywheel installed along with the zspeed new slave ... IS it normal to have about a inch of slop in the clutch pedal after install?? Whats really weird is everyone talks about how much chatter this thing makes and it is so quiet . My oem clutch was noisy compared to this ... Any ideas ????
that is weird how you don't have the chattering. i had it and hated it every minute. removed it after 1k miles.
I think replacing the spring will take up some of that slop. I think you might notice some gear rattle in the tranny after you get it warmed up, at least I did when I intsalled a single mass flywheel.
Yes, that will take out some of the play...also there may be some air in the system that has to work out. After I changed mine I power bled the clutch with a pressure pot system and still had a mush pedal for a while (slop) within a few days it worked itself out and all is good now.
You can adjust the pedal a little tighter to get rid of the slop so long as all the air is out of the system.
Basically break the nut loose a the master cylinder rod and turn the rod 1 turn clockwise, if it is not gone turn one more. Just go a little at a time, 1 turn moves the engagement point a lot.
Thirty_Seven
12
08-16-2015 01:48 PM
david77845
08-10-2015 12:46 AM
