Definitive break in period
So I bought my 2011 G37 sedan 6mt (mouth full) in the beginning of December 2010.
I have 2200 miles, all freeway, on my car now and have been hearing about break in period.
What is the standard break in period? This car has crazy resin coated pistons.
I have yet to take the engine past 5500 rpm, when I hit 2000 miles I did it once and felt uneasy about it.
i took mine past 4,000 revs before the initial break period was over. i read someone that in a comparison between an engine that had been broken in "properly" versus one that was broken in via "driven like it was stolen" or with one's "typical driving standard" and the latter showed better internals. just sayin'
have fun!
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
OK, I read the manual for you.
The break-in period is 1250 miles. Don't go above 4000 RPM. And let car idle for 30 seconds before driving.
You're welcome.
You're welcome.
![Wink](https://www.myg37.com/forums/images/smilies/wink.gif)
I don't think Nissan/Infiniti has changed their break-in period recommendations since the original 280Z. I wouldn't worry about it too much. Just use common sense.
Here is an often-discussed approach, and even though it was written for high performance motorcycle engines, it is recommended often on forums discussing high performance car models that have some tendency for oil consumption in some percentage of cars.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
(I'm not recommending it; never tried it. Many people seem to believe in the method though, and at the very least it's an interesting concept which car manufacturer lawyers would never embrace even if it was unanimously proven to be a better approach than what owners manuals say).
I do recall that when i first test drove my vehicle...which was just off the truck with all covers on & 14 miles on it, i floored it few times during those 5 test miles. When i bought the car, it has 31 miles on it.
Not sure...which to follow or believe. I am past the break in either way. I am going to just enjoy my ride.
I just do what the manufacturer says to do in the manual.
Since oil consumption (combustion) is what the method allegedly cures, it sure seems a controlled experiment is possible (but it would be expensive since you'd need multiple virgin cars as samples).
It's possible it might vary by engine model, probably by oil type and viscosity too. That adds more variables and more expense to the controlled experiment.
Manufacturers have no motivation to do it since most of them use the claim that up to 1 quart of oil consumption per 1000 miles is "normal."
