G37X NEEDS manufacture update on the DS Mode
I have a 2010 G37XS... a trade from the 2008 G35X
DS mode of the G37X does not act like a DS mode vs older Gs.
1) It goes back as if you are running D mode very quickly and goes to high gears
2) Going on turns, it does not downshift as fast as the old Gs unless you give it HARD breaks. And then it upshifts real fast as if you are back in the D mode.
There are several other problems but the final point is that it just DOES NOT ACT LIKE A DS mode and Infiniti needs to update and re-program the DS mode in the new G37. When we are in the DS mode, WE WANT DS performance and not save a 1$ or 2$.
Please pass this info and get this matter heard by Infiniti so that they would send out a patch or update the ECU.
mymarch: Unfortuantely, the new 2010 G37s do not Drive like my older 07 G35 in D Mode or DS Mode. It's the result of "new technology" of the 7 speed AT. Check the treads about the Transmission Issues. There are at least 10 pages of messages (including a number left by me) about the TSB ITB10-077 which deals with the 4 to 3 hard shift BUT seems applicable to other driveability issues of the 7 AT Auto G37s....... There are posts from people that have had the Reflash of the ECU done - some good results, some No Change results, some - I guess bad results... I was supposed to get it done, but I "chickened" out for now. I'm still testing mine. After 8 k miles on the car, I have found it less jerky (not Gone but less offensive), But a slight Lag exists. I know what you mean about the DS mode, it is differently different in this car, but as noted earlier, the blame lies on the 7 spd AT. Better mileage is there - at least I'm seeing that over my 07 G35X.
I don't mean for this to sound bad...but are you sure you are driving in DS and not in D? The above two points are exactly how the car should act in D. If you are truly in DS, I would bring it in as there is something wrong. I have had two Gs, and my DS works for the most part the same in my '10 as it did in my '07.
OP try this...
1. Unhook the negative terminal ~10 mins.
2. Wire it all back together
3. Reset your windows.
4. Drive your car like you stole it for ~10-15 miles.
5. Enjoy!
These cars come with a dynamic "learning computer" if the car feels sluggish, thats because its used to you driving it like a grandaddy!!!
5. Enjoy!
Yes it does that. It changes the shifting patterns mostly. My DS mode is now very much like my D if I am just driving along. It is only different if I punch it or brake, then it will hold gears longer. Once my speed steadies, it goes right back to being like D.
OP try this...
5. Enjoy!
5. Enjoy!
Would we want a stupid car that holds gears and acts like you are racing it ALL THE TIME IT IS IN "DS" MODE even though you are experiencing a variety of conditions? If you are at a race track, you should be using manual mode. If it is in DS, it means you still want some automatic operation.
I obviously can't compare new and old, partly because I have a 6MT, but I'd imagine that putting a car in DS wouldn't stick it in gear forever. I mean, automatic transmissions are smart, but they can't read your mind. If you really want that much control, why not use the stick and shift yourself?
I feel you though. Being used to one thing and getting another can be jarring.
OP try this...
5. Enjoy!
5. Enjoy!
Do you suggest it's a good thing to do to reset the terminal right after the 1000 miles mark ? Is it gonna have a noticeable improvement ? Also, if someone else drive my car, would it "relearn" into being sluggish again ?
Thanks !
So ... I am driving my car like a grandpa for it's breakin period.
Thanks !
Thanks !
Which is exactly what it should do. Act more or less like D for placid driving, but with cat-like response switch to sport mode as soon as any aggressive throttle or brakes or cornering occurs.
It is far from cat-like now. I honestly would prefer something between what it was when I bought it and what it is now. I don't want to start over and reset the ECM though.
footballmania32
09-04-2015 02:17 PM
