Review First Twin Turbo Oil Change
Nice write-up.
Mobil 1 0-40 is actually a very good oil for the VHR-TT. I believe that is what GTM put back into the motor when you got your car back.
I've had M1 0-40 in mine since the day I had the TT installed (but I have an HR and live in a warmer climate?). I also have Blackstone Labs do a UOA on EVERY oil change with no issues. Over 30K boosted miles so far and my next oil change will be at 8K miles.
As for how i did the change, I also used ramps along with 2x4's to get the clearance I needed.
Thank you. The hardest part of the whole thing was actually getting the car off the ground. After that it was easy. im sure using the ramps and 2x4 3x4 will make the next time I change it much much easier
I plan to keep everyone updated on everything that happenes to the car. You guys are crazy for more information so thats what ill try to do for ya guys
I'm not that familiar with the Gtm turbo setup, are they water cooled or oil cooled?
I knows its a completely different setup but on my evo and sti I liked 10w30 in the summer and either 0w or 5w-30 in winter. I did the same when I supercharged my s2k.
A quick and dirty way to see how your oil is doing is look at the oil drain bolt. Most are magnetic and metal particles will stick to it. Everything should look like fine sand, if you see anything bigger or there is a lot of it post a picture.
UOA will show if the oil is shearing/breaking down.
A lot of those particles usually settle at the bottom of the oil pan and don't circulate. The magnetic plug just tries to pull some of it towards itself to help keep it clean.
I've changed and seen changed a LOT of oil. I've never seen a clean magnetic plug. You have residue from break in that sits on the bottom of your oil pan for years. About the only way to completely get rid of it would be to drop your oil pan and clean it out.
Really and for true?
If you want the full details, they can be found on page LU-3 in the FSM. Index of /FSM/G37
ATM it has been way to cold and snowy for me to even think about driving my car. However when it starts getting hotter outside Ill take pictures of my gauges to show how hot my motor is getting and all the other good jazz. Have not driven the car since the oil change.
Do you start it and let it warm up at least to keep the oil moving and the parts somewhat lubed or is this an old car routine? I know that it is an issue with our 66 Jaguar. It sits most of the time, so we do this periodically to keep some oil coating in the heads and stuff...
#29
Victory
09-28-2015 10:49 PM
tite_tite
09-25-2015 10:21 PM
ryang37x
09-22-2015 05:33 AM
sharmelan
17
09-14-2015 03:18 PM
