Infiniti engine bay emblem
No it won't. The Letters come on a long adhesive sheet spread out and pre-measured and aligned apart. You only have to draw a (with a grease pen) horizontal line and measure the centering of it and done. Pretty Easy. Just use a grease pen to mark the measurements.
The front grill emblem is a chunky emblem with clips and will not lay flat on the engine cover. The emblem for the engine cover is not sold separate from the cover itself from Infiniti.
Luggage Lid, so thats for the trunk.
Here's one for the hood
NEW OEM INFINITI 2008+ G37 COUPE FRONT GRILLE EMBLEM - eBay (item 180602475544 end time Jan-17-11 08
32 PST)
Not sure if theres a difference, but get the "front grille emblem" to be safe. Or call Infiniti and ask if theres a difference.
![15](https://www.myg37.com/forums/images/smilies/15.gif)
Yep, here is an example for you: Amazon.com: Infiniti G35 JDM 350GT Emblem: Automotive
Did you try to see if it had popped off and is laying on the bottom engine cover? That cover below if correct doesn't have any holes big enough for the emblem to fall out. It might be down there. Also if someone was to steal it you would probably find some pry marks around whee the emblem sits.
![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
^^ Yeah man I think you might have to buy the whole engine cover. Buttt.. you could post an AD on this forum to buy a used engine cover from one of the Performance Modders here. There are some that are replacing the cover with carbon fiber covers. They would be your best bet in price.
Not to bump this, but did you ever get a solution to your emblem problem?
I believe my dealership split some oil on my cover and it "burned" into the cover a few oil changes back. I didn't mind it much, but now they took it a step further and popped off my engine bay cover emblem. There's no way for me to prove this as I didn't notice the emblem missing right away, and they refuse to replace anything.
Where can I just get a replacement cover + emblem? or anybody have it for sale?
I'm more interested in just the emblem. Would you sell just the emblem? I'm not too interested in getting a non oem color cover. Out of curiosity, where & how much did you get your carbon fiber cover for?
#29
I tried finding a replacement emblem on ebay and tried several sizes but none fit perfectly. I ended up finding an "un-used" engine cover on ebay listed at $15.00 and bid on it and won the bid. It was in fact pretty much un-used.
David
