G37 7speed transmission reprogram
#946
so the arguments on the tranny all talk about programming, sw, and how other cards dont do it etc but nobody mentions the traction control... I can tell you in my other car if I do what is mentioned here to reproduce (slam on brake and then shove the throttle on the firewall) the ATC will kick in and cut power to mantain control... yes granted its a C6 with 400ftlb of torque but the point is could this simply be the car lagging power to ensure traction is held? What are the road conditions when it happens? what is the tire wear?
Has someone turned the traction control off and still experienced it?
#947
Document, document, document, then when Nissan tells you repeatedly after many failed reprogrammings that the transmission operates normally, if you are in Canada, use the Canadian Automobile Manufacturers Vehicle Arbitration Plan (CAMVAP.com).
I received an Arbitration award, and Nissan was ordered to buy the vehicle back. Nissan resisted all the way, 'defending' the operation of the transmission as normal, and criticizing my driving style. The Arbitrator saw it differently.
I had my vehicle over 1 year and the entire ownership experience was hell. Many times I felt like giving up and trading or selling the vehicle. Perhaps that was the Nissan strategy.
Everyone with this issue, in Canada, should use the CAMVAP process. Good luck to all of you, and don't give up !! I hope to see more postings like mine in the future.
#949
I don't have the issue, but I have felt "some stuff" in the tranny. When I know I want to hit it though, I shift into DS mode if I'm going to hit the gas heavyily.
#951
My car was updated yesterday with new ECM flash and programming. It certainly feels a lot more responsive now, especially when slowing down in traffic and hitting the accelerator to speed up. Definitely an improvement.
#952
Can you please post the specific details of the update that was performed on your car?
#953
ITB10-075A
Updated ECM and TCM Asper Bulletin.
Service rep told me they performed two items. Certainly the number is the same but not sure if both items are covered in the original update. Sorry if this is the same thing, I've only had the car since July. I was exclusively a VW owner for the past 10 years. Have to say, great car overall but miss the feel of a German car.
#955
#956
I'm looking at the paperwork now and it states the following:
ITB10-075A
ITB10-075A
#957
Those of you who know me on here will know I am a hold-out with original programming on my '09.
After driving a '12, I am now ready to get the latest update. Since there are so many contradictory comments about the changes I will add mine to the mix.
2009 Programming:
D Behaviour:
Fairly aggressive downshifting. Responsive upshifting...tending towards letting the rpms go to the higher end of the spectrum.
DS Behaviour:
Very aggressive downshifting. Aggressive upshifting with anything other than the lightest throttle.
2012 Programming:
D Behaviour:
Mild downshifting...equivalent to most other auto tranny cars out there. Responsive upshifting...tending towards letting the rpms go to the higher end of the spectrum. Slightly smoother shifts both up and down.
DS Behaviour:
Fairly aggressive downshifting. Responsive upshifting, but will act like D until fairly aggressive throttle action is applied.
In summary: The 2012 DS is similar to 2009 D. 2012 D is now similiar to an everyday car rather than like the 2009 aggressively keeping the car in the right gear to pounce on a moment's notice. If you want 2009 DS behaviour in the 2012, better get used to using manual shift.
For me, I rarely use 2009 DS because it is too pronounced an effect...unless you are at a track day. The new DS is a very nice balance in my opinion. If I was at a track day, I would use Manual shift regardless--no automatic shifting will ever be sufficient, so it was a bit of a useless mode. With 2012, I can imagine using DS the vast majority of the time. It will be retain the same downshifting I have now in D that I like because you don't have to use the brake so much in urban traffic (if you anticipate traffic properly) and will only go into aggressive mode if I want it to by applying some decent amount of throttle.
The new D would be fine for people who don't really want a sport sedan. I can imagine occasionally wanting to "coast" along as if I were a grandpa. It is at least smooth and predictable.
For any serious driving, I have the paddles and Manual mode.
So, I will finally go for the update at the next convenient opportunity. The new DS is a blend of the old D and DS keeping the right elements. D is there if you want to pretend you bought a Lexus ES. And M is still there for serious driving. At first glance, it seemed like they just dumbed-down the programming (they did, a bit), but I think it is actually a good blend of useful options.
2009 Programming:
D Behaviour:
DS Behaviour:
2012 Programming:
D Behaviour:
DS Behaviour:
#958
@Marc Collins:
A couple things to note:
ITB-075A has been around for almost 12 months, and is the currently available update for 09-11 G's.
ITB-075A makes the car like a late 2011, not a 2012. I know because I have a late 2011. In response to my complaints about the issues with the shifting they tell me that I already have the latest software available, the same version as what would be applied with ITB-075A.
I believe we do not know for sure yet if the software version is different for 2012 models or if it is compatible with 2011's (though I would think it should be).
I also don't think we have evidence yet that the 2012 "fixed" all of the issues that people have complained about with the 2011 and the current ITB-075A update. I will need to drive a 12 myself before I am convinced, because I have never experienced a G that did not have the same problems mine does.
SO, I would hold off on your update. ITB-075A will give you 2011 behavior, not like the 2012 you drove. This is based on the idea that 2012 is different than 2011. If true, then I would expect a new ITB soon after Infiniti is convinced the 12's produce less complaints. I have yet to drive a 12.
#959
#960
Also been keeping my eyes open for a replacement vehicle, BMW or Audi most likely.
So, yeah, I want to know about the 12s, but the Infiniti dealership is frankly the last place I feel like going. I get the oil changed at Nissan which is nearby.
