Gear Ratios
Gear Ratios
I know Z1 Performance has a final gear in the ratio of 4.08 but is there a way to just alter the first two gear ratios for increased acceleration off the line without altering top end speed? Like a way to change gears 1 and 2 in a 6MT while leaving 3,4,5,6 alone? This may be a stupid question, but someone please enlighten me....Thanks!
Don't worry about top end speed.. its limit wont affect you because you can't even reach the physical limit. Do yourself a favor and avoid z1 performance.. Horrible customer service... THe gear you are changing is not the transmission gears... Again don't worry about top end I am on a 7at and I get to 100 MPH on 4th gear and I have 3 gears to go.. I can easily hit the computer limit thats at 150.. and do you really ever need to go past 120? or even 100 for that matter?
There's no points in changing the gear ratio spread, at least on the street. If you're going to make 1,2 quick than shifting to third would be pointless and you would have to shift again very quickly.
For the 4.08 gears? Use MyNismo.com - Home Page I had 0 problems with them. Now z1 that's a different story they were very unprofessional and they seemed not to give a rats ***
37
10-17-2020 11:12 AM
r0cketm0nkey
General Tech Questions
17
11-23-2015 03:34 AM
Slapshot1
09-27-2015 08:40 AM
