Better results with Cobb custom tune
Old 11-29-2010 | 01:25 PM
draper's Avatar
draper
Saw Brian at APH on Saturday and happy with the results so far.
We did baseline an 3 Cobb maps and the factory ecu on dynapack dyno. Off the Stock style, Stage 2 and Stage 2+, Stage 2 looked better to start with. Brian was hesitant to tune first but after looking at Stage 2, he said he can tune it little bit more.
I think the peak HP was around 9 hp but could be more if we had done some more pulls, there is power gained throughout the power band and torque has definitely gone up. Car definitely pulls stronger than before and better than the other tuner.
Brian is good tuner though he still thinks this VQ is same as before !!!.
I should ask money back from the tuner but he seems hesitant.
the last one I think is the comparision between base run and tuned.
P.S It has been 400 miles + and so far no SES.
Base run was done with Stillen Gen 3 intake, CNC HFC and Magnaflow CBE. No base run with stock only.
Attached Thumbnails Better results with Cobb custom tune-base_mod.jpg   Better results with Cobb custom tune-cobbst2_mod.jpg   Better results with Cobb custom tune-cobbst2-_mod.jpg   Better results with Cobb custom tune-2ndtunedmap_mod.jpg   Better results with Cobb custom tune-g37-aphtuned_mod.jpg
Old 11-30-2010 | 04:24 PM
Legz's Avatar
Legz
Interesting, glad it worked out for you
Slapshot1
09-27-2015 08:40 AM
Quick Reply: Better results with Cobb custom tune
