High RPM shift 1st to 2nd wall
QFT, the smoother the transitions the faster the times usually, all my fastest times at the track felt like I was slow compared to slower times I ran when I felt like I was driving like I stole it. Moar wheel spin, less accel.
i starting to feel something when i shift from 2 to 3 just feel like i'm hitting something metal before i go into gear! but its not locking me out. i might bring mine back or call my dealers and ask them it might be some problem in the future when your warranty is out lol..
Thanks for the replys. Yea 2nd goes in just fine when I'm normally driving at 2.5k shifts. The clutch has to be fully disengaging since I can feel the long dead travel of the pedal before friction point right? Yea I attempt to shift way before you do in that video. I'm thinking a syncro problem may be showing up, and this is why I'm wondering if I should let the dealer take a look at it. I'll take it to get looked at next month now that I know for sure it's not normal to get so much resistance to get into 2nd.
pedal is down to the floor (half of it is dead travel anyway).
You should have someone bleed the clutch fluid system.
Have you checked if the fluid reservoir is full?
Maybe a bad clutch master cylinder/ slave cylinder.
1 to 2 is not forgiving of bad clutch hydraulics, but the rest of the upshifts can almost be done without a clutch.
redlinernyc
02-29-2016 11:06 PM
KZK
Canada
09-23-2015 11:52 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
inspector94
09-08-2015 12:57 PM
