Gtm
I think you have a loose or cracked vaccum hose. This happened on my APS TT kit. I found a very small crack in one of my vacuum lines and it would stall every once in a while, especially at idle after a quick throttle. Never on the highway though. You can get a vacuum guage to test all the different areas of the lines.
check them out.
check them out.
back in the early g35 TT/supercharger days, after one let off the throttle and the throttle body blade closed, the car would stall... this would happen wheather in park or while driving!
the easiest solution was to drill a small 1/8 inch hole into the throttle body blade, thus always allowing a small amount of metered air into the engine.
this also helped with people who had shaky idles...
i had to do this on my car with no ill-effects!
i dont think it be fuel or spark plugs. for all that was switched out at the shop. i really have no idea what the problem is. car runs great. just except this lil problem. like yesterday i was pulling out of the drive way and turned left. it died as i was turning going like 10-15. the other day it happen. my girl was in the car. and i told her my car died. and she didnt believe it till i had to fire it back up. so its happening quite often now.
i just want to beat my car with a bat right now. its frustrating.
#29
Just to add, seeing as anything can be the culprit given the symptoms, check the cam position sensor. The random stalling reminds me a lot of my Maxima. For a few months there were no codes so nobody could tell what was wrong. Eventually, thankfully, an SES light finally came on.
Replaced the sensor and it's been running great since.
#30
yeah im waiting for sam at gtm to send over the uprev cable and stuff over the email. after that then ill see if the problem goes on. its just been a month i been waiting for all this. its going on month number 2.
