Help Just Ordered my 4.08 Final Drive
So I just ordered my 4.08 final drive from mynismo.com. Going to install it on my 7at g37. Anyone have any tips before the install? Is there a break in period? Also this might be a dumb question but do I need to change any fluids because of the install and if so any recommendations?
Thanks guys I hope to have this install within 2 weeks but knowing me itll be most likely a week .
Considering the questions you are asking, you realize that this is NOT something you should try to do by yourself, right? I'm not knocking you (I'm not doing mine myself either), just making sure you don't have a disaster. You will need to refill the differential when it's put back in the car. You really need a shop who knows what they are doing to swap out the gear and adjust it properly. Removal and install of the differential isn't too tough, and you could possibly save a few bucks by doing that yourself if you want. I searched for a very long time to find any place that would even touch it around my area. And be aware that your cruise control will no longer work once you have made the swap.
I didn't know if you were going to try to DIY.
Page 9-2 in the owner's manual tells you this: Genuine NISSAN Differential Oil Hypoid Super GL-5 80W-90 or API GL-5, Viscosity SAE 80W-90
I plan to change my oil in the differential about 3000 miles after the gears are swapped. Here's something to read:
Proper Differential Maintenance Break-in and Routine
I was reading your diy for changing differential oil and you uses another type of oil. How is that working out. Also I assume from your last sentence that you are going to perform this mod as well
Did you need to add any additive to help the gears lock or are you having no problem?
Hopefully i can just replace ring and pinion and dont need to replace anything else. I am seeing some 370z's with 7at replace the whole dif well it was just one guy and the post was from 2009 so I am hoping i can just replace the ring and pinion.
