Help Just Ordered my 4.08 Final Drive
I had no idea that the Japanese Skyline has the finned cover. If that's the case, they will probably be more expensive not to mention expensive shipping from Asia. I'm 99.9% sure there's no difference though. Enough so that I should just go ahead and get it. I'll find out when I have it. If it's wrong I can just eat the restocking fee.
https://www.myg37.com/forums/general...anual-fsm.html
If you are seriously interested in doing this then download the Factory Service Manual and read it. It's all in there. Since you seem to be search impaired, I'll even spoon feed it to you.
Sorry I missed this thread.
From what I researched, there is some difference between the rear housings of the manuals and autos. I don't know what is different but it seems that the gears are specfic for the manual housing.
And the cruise control issue has to do with the logic. For automatics, the cruise control logic looks at both the transmission output speed and wheel speed. If they are inconsistent with one another the CC will not work. For the manuals, the cruise control logic does not look at the transmission output speed.
Florida G Club
Just spoke with Z1 they are telling me that if I want to use the 4.08 final drive for the auto I need to change the differential itself. They are offering a nismo differential for 1150. I am just trying to think if it is worth it or not. I have no more performance mods left to do on my car other than get a tune and thats a whole other story.
Total cost is going to run around 2k+ to change everything. That is including installation. The problem is the car is a lease...
#29
The GCC spec G/Z's come with finned diff housings. You guys have differential housings with flat bottoms. These are different from the diff cover posted earlier, so technically there are two finned pieces that you can get.
#30
"Nismo differential for $1150", is that for a differential or for the whole housing? Sometimes people use "differential" when describing the whole rear end, when the "differential" is actually one of many parts inside the housing.
