Help I just want to squeal some wheels, man.
Old 10-03-2010, 05:13 AM
jc562
jc562's Avatar
Originally Posted by Mazaki
Neutral drops?
rev the engine in neutral then throw the car into drive while flooring the gas.
you can also try some skinnier less sticky tires. that way when you f up the tires they will be some inferior lower cost tire instead of the stock potenzas im assuming.
Old 10-03-2010, 05:17 AM
Mazaki
Mazaki's Avatar
Won't that damage the transmission?
My old BMW's auto would never let me shift into Drive from Neutral unless the car was under 2000 RPM... Or was that just a safety thing?
Old 10-03-2010, 05:26 AM
wlmngtn
wlmngtn's Avatar
Ive been trying to do the same, but my damn tires just chirp... I think a bird chirps louder and for a longer period of time than my 7AT coupe....
Old 10-03-2010, 05:49 AM
speedracer g37
speedracer g37's Avatar
it's been 60 here in the mid atlantic and the tires get loose on my 6mt up around 5500 rpms. the tires light up going all the way through second gear until i have to shift into third. tires spin in third gear for a bit too.
i feel your pain though man, i had a 5.0 liter mustang auto that wouldn't spin tires in a straight line.
Old 10-03-2010, 09:20 PM
911turbo
911turbo's Avatar
i chirp 2nd =)
Old 10-04-2010, 03:10 PM
SpartanG37S
SpartanG37S's Avatar
6MT FTW! I can spin tires in 3rd gear Oh yea, FWIW, neutral drops are bad for your tranny. Wanna do burn outs? Get crappy tires.
Old 10-05-2010, 09:53 PM
gsm026
gsm026's Avatar
I read somewhere (maybe on the 370Z forum?) that the software intentionally pulls back the throttle response curve at the bottom of first gear. So if an aftermarket tune can recalibrate or remove that, it might solve your problem.
My old 3.2 TL with the 5AT would squeal the tires off the line much easier than my G37, despite less power and taller gearing in first. The G is a much faster car - it would absolutely eat the TL alive, at least after the first 10 feet or so.
Greg
Old 10-05-2010, 11:29 PM
Mazaki
Mazaki's Avatar
That's what I read here, the ECU doesn't open the throttle 100% even if you floor it. I assumed a tune would correct that.
Old 10-05-2010, 11:39 PM
speedracer g37
Originally Posted by 911turbo
i chirp 2nd =)
90 degrees and 80% humidity i bet...move to a colder dryer place and you'll chirp 3rd.
Old 10-05-2010, 11:50 PM
Gamedog
Sam Rothstein
Gamedog's Avatar
Old 10-05-2010, 11:52 PM
speedracer g37
...and wait for the transmission to fall out
Old 10-06-2010, 12:09 AM
Mazaki
Mazaki's Avatar
Old 10-06-2010, 12:18 AM
PictureMeRolin
PictureMeRolin's Avatar
Get one of these
BLITZ Throttle Controller for G37 Available now from Amplified Motorsport - MyG37
Old 10-06-2010, 02:11 AM
  #29
bringmedasuga
bringmedasuga's Avatar
Try this one..step on the brake pedal and gas at the same time (step pretty good on the brake pedal) when its up to 3500rpm, step off the brake pedal for less than a second and then step on it again really hard (never steping off the gas) and then put some more gas. Releasing the brake pedal at the beginning will shift your car's weight-energy to the back, by braking rapidly it'll shift it to the front, this momentum shift to the front (by the second braking) will allow for the rear end to be "less heavy" for just a fraction of a second and as a result the tires will spin easier. Once theyre spinnning step pretty good on the brake (and gas) pedal until you feel the tires will have a long fight to get the grip back after you release the brakes again, then there youll have yout itch gone
Old 10-06-2010, 03:41 AM
  #30
Mazaki
Mazaki's Avatar
I don't think the car will actually rev that high with the brake engaged.
Damnit, why didn't they do a launch control thing like on the GT-R?
Quick Reply: Help I just want to squeal some wheels, man.
