Manully shifting the 5AT
whats the difference between the transgo vs the gtm kit. there is a quite a big price difference.
Sounds like the transgo kit is the way to go. BTW on GTMs website they say that if they install the kit they do some additional modifications to "optimize preformance". Anyone know what they're referring to?
The valve body is the brains of the transmission. Most places out there that modify transmission valve bodies will start with the transgo kits and then add to it. Transgo (and a couple other companies) do a good job of upgrading the basic components they feel will help the most. Really good tuning companies expand deeper into the valve body and pick and choose their changes. Depending on the transmission this could include, machine work, new components, modifications to electrical components (such as adding resistors), adjusting settings on exsisting components, and maybe some black magic. The really good companies usually don't want to share too much of their info.
I have three valve bodies for my truck. One is stock with a transgo kit that I installed in it. The second is from a company that does custom valve bodies and it's their "Stage II" set up, this is the one I currently have installed. The third is their "Stage III" which I haven't tried yet, but might put in a buddy's truck to test it out. The best combo I have for my truck involves a tuner that can change transmission shift points, line pressure, rev limiter, and downshift settings.
I don't know what GTM does with their valve bodies but rest assured there is a lot of changes they can make. I wonder if they are willing to share what all it is they do? With what little I know of the G37, I'm pretty sure the best combo would involve some TCM adjustments as well.
Transgo Valve Body upgrade isn't too difficult. I've done it on several cars to date. It seems daunting at first, but if you take you time and double/triple check every step you'll be fine. I haven't seen an option out for the 7AT yet, but its great in my 5AT. Shifts are lightning fast.
Some other companies that specialize in modifying Nissan transmissions and valvebodies:
Level 10 Nissan Bulletproof Valvebody RE5R05A,RL4F03A,RE4F04A,RE4R01A,RE4F04B,RE4R03A,RE 5F22A
Nissan Infiniti Modified Valve Body
517 Trans - Catalog - Infinity
Does anybody know what the effect of also installing an upgraded torque converter such as the one offered by GTM in addition to the TransGo kit?
GTM Motorsports*Torque Converters
I don't know if they custom fit those Torque Convertors to each customer or have a shelf full of them. TC's need to be specifically made for the intended application if you're doing things right. They need to ask you things like, the weight of the vehicle, the engine power curve, gear ratios, what you indend to drive the car for, and things like that. They can spec out the torque convertor by changing things like where the TC stalls at and what the torque multiplication is. Good TC's will an "anti-ballooning" features such as billet aluminum plates and talk about true stall vs flash stall vs brake stall.
Do a quick google search for torque convertors and you'll find more info than you'd ever care for. You'll also find that the GTM page you posted above tells you nothing other than they can sell you one.
I'd talk to Sam before going with a different TC. I wouldn't change the stock unit though. If you want trans upgrades just go with a VB upgrade and a nice oil cooler. Make sure you use high quality fluid as well.
Looks like that's the case... unless the car is putting out some massive numbers, an upgraded T/C doesn't seem to be worth the money. I may go this route if I ever do the S/C...
I think I'll be ordering my TransGo shift kit very soon, and attempting the upgrade myself. It looks complicated based on all the screws you have to remove, and the fact there is some drilling involved, but from what I hear it is more of an organization thing, and that the TransGo instructions are very clear and precise.
And the money I'll save on the install I can use on sway bars and some good tools!
Thanks! Haven't heard of this... found this weak DIY at Nicoclub:
5AT - Transgo Valve Body Shift Kit - DIY : G35 and G37 General Discussions
Looks intimidating to say the least... did you DIY or pay for install? How much was install if you did?
