Anyone upgrade the stock radiator?
Old 07-28-2010, 10:32 PM
Weiboy718
Weiboy718's Avatar
Originally Posted by kame_sanjo
Yea I'm not looking for better numbers just cooler water temps. It gets to around 115 to 121 in las vegas and sitting still in traffic is no good. Coolant got up to 143 a couple weeks ago so that was fun. Everything seems to be forthe g35 at the moment. Wonder of they have a retrofit, haven't seen anything.
how are you monitoring your water temps???
our radiator does a pretty good job cooling the coolant. don't think you need it unless your water temp always hovers over 210-220. if that's the case you'll need a new thermostat so that it opens at a much lower temp. or you can upgrade your radiator fan and hook up a manual switch to it.
Wait a minute, are you talking about the outside temperature display??? That has squat to do with your car's cooling system! That's outside air temperature and it's not particularly accurate all the time, especially when you first start the car after sitting in hot temperatures like LV.
Your coolant temperature and oil temperature are what matter for your engine. They are both significantly higher than 143 while your car's running. We have no stock oil temp gauge. The coolant temp gauge should point right about halfway up when operating normally.
lol! hahaha! i thought for a minute how can his coolant temps be so low? our normal coolant temp is somewhere between 170-190. anything after i believe 210 our fan should kick on.
Old 07-29-2010, 07:02 AM
Team Punisher
Team Punisher's Avatar
No super G. Not sure what up but water temp never seems to get pass 1/2 way mark and car has not gone in to limp mode....
Old 07-29-2010, 08:02 PM
kame_sanjo
kame_sanjo's Avatar
the temp gauge is not going to go above half on your dashboard until it is overheating as far as i know. only time ive seen that was in my work truck a while ago when the thermostat broke and it would go all the way to the top, and thought my car was overheating.
Old 07-29-2010, 08:03 PM
kame_sanjo
kame_sanjo's Avatar
i am using camp2 and the external sensor package to monitor water / oil temps.
Old 07-29-2010, 08:06 PM
kame_sanjo
kame_sanjo's Avatar
man i am stupid, i meant 243. dude i dont know where i got 143 from. yes, i hang around 190-210 when im driving depending on weather and if im on the street or highway. oil is about the same
Old 07-29-2010, 08:29 PM
Now THAT makes more sense. I figured there was something screwy about your math somewhere.
Old 07-29-2010, 08:42 PM
Weiboy718
Weiboy718's Avatar
HAHAHAHA! all good man! i was like 143! that's not even on normal operating temp lol. yeah, you gotta find a way to keep the water temp lower. 243 is too high and getting very close to the boiling point. mines stays at 175 driving and 200-210 on idle.
i have the HKS CAMP 2 also. did you hook up everything yourself?
Old 07-29-2010, 09:12 PM
B L U E S L A T E
B L U E S L A T E's Avatar
AFAIK.... Stillen offers an aftermarket solution for the radiator. I know that it fits the 370Z, but I'm not sure if it will need a new bracket or if they offer the same for the G. I've seen them at their open house meet.
Old 07-29-2010, 09:22 PM
Have you tried Red Line Water Wetter? Living in Vegas, you might also be able to run a lower percentage of antifreeze than 50/50 (maybe 75/25?) and get your temps a little lower.
Old 07-30-2010, 06:57 PM
kame_sanjo
kame_sanjo's Avatar
havent tried any solutions like that, i will give it a shot, thanks for all the input!
my local shop put all of the sensors in place.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
ck1109
10-20-2015 03:34 PM
Thirty_Seven
09-18-2015 04:41 PM
Wicked-G
08-25-2015 11:21 AM
Elitoh
08-19-2015 02:16 PM
Quick Reply: Anyone upgrade the stock radiator?
