Oil Cooler Installed
Old 07-11-2010, 10:55 PM
Weiboy718
Weiboy718's Avatar
total time took about 2 1/2 hours. here's some pic's from start to finished. enjoy!
first i installed the oil cooler on the car.
then i cut some holes and run the hoses through
after that drain your oil and remove your oil filter. then install the sandwich plate. it took me a bit to jiggle with the hoses to clear all obstacles on the frame then i used some foam insulation to wrap up the hoses to protect it from rubbing against metal. finally got it on!
end results.
thanks for looking.
Old 07-11-2010, 11:26 PM
A_Palaroan
A_Palaroan's Avatar
looks good man
PennywiseG35S
PennywiseG35S's Avatar
Where did you buy the oil cooler from? How many degrees did your oil temp drop on average?
Old 07-11-2010, 11:47 PM
Q8y_drifter
Q8y_drifter's Avatar
How do you drain the fluid in the cooler when you go for an oil change?
Old 07-11-2010, 11:48 PM
Weiboy718
Weiboy718's Avatar
got it from
Amplifiedmotorsports.
i'm not sure how many degrees it drop since i don't have a oil temp gauge yet. well, i just bought the oil temp sensor for the hks camp2 but it's far too complicated just to get that installed. waiting for my oil pan spacer to come in so i can tap it there to get the readings. i'll let you know soon.
Old 07-11-2010, 11:56 PM
Ivoidwarranties
Ivoidwarranties's Avatar
Good work. How much oil did you have to add to fill the lines and cooler?
Old 07-11-2010, 11:59 PM
Weiboy718
Weiboy718's Avatar
very close to 8qts. it's gonna cost an arm and a leg each oil change now lol. it might be 8 1/2 after the oil pan spacer.
check out my dyno sheet and video if you have not seen yet.
https://www.myg37.com/forums/g37-cou...a-time-at.html
Old 07-12-2010, 12:06 AM
CougarRed
CougarRed's Avatar
Why not a dual remote oil bypass? Amsoil part BK23?
Get cooling and awesome filtration.
Old 07-12-2010, 12:19 AM
Weiboy718
Weiboy718's Avatar
is that gonna help more than the oil cooler?
Old 07-12-2010, 02:09 AM
NeverBoneStock
NeverBoneStock's Avatar
Weiboy... Can I get your # so I can talk to u about your set up?? Thanx Blaine
Old 07-12-2010, 09:42 AM
Ivoidwarranties
Filtration was not the issue, the high oil temperatures these engines can produce was.
Old 07-12-2010, 10:15 AM
Greg Lecewicz
Greg Lecewicz's Avatar
http://www.oilsandlube.com/amsoil%20...DualRemote.pdf
Old 07-12-2010, 10:46 AM
Weiboy718
Weiboy718's Avatar
Originally Posted by Greg Lecewicz
That's not gonna help much for a supercharger or turbo application. It'll help cuz you're able to run a extra quart of oil but I don't see this bypass have cooling abilities.
Old 07-12-2010, 11:15 AM
da mayor
da mayor's Avatar
cooling abilities will require some ECU modding... you're gonna hit 275 degrees fast
Old 07-13-2010, 11:38 PM
Weiboy718
Weiboy718's Avatar
i wanna add another cooler like what Shumby did haha! that's a killer setup!
Quick Reply: Oil Cooler Installed
